Ctrl c not working
2009-05-11T08:55:36+00:00
Hello, somehow I have managed to disable the shortcuts for cutting and pasting. I can only do it manually through the menu bar. I cannot Ctrl C or Ctrl V anymore - nothing happens! What have I done? Please help.
thanks
Nicole
(am using Word 2003)
2010-02-03T00:02:47+00:00
Annoying problem if you rely 100% on keyboard shortcuts!  I had the same problem and the fix is very easy.  You will need to uninstall your keyboard driver and restart your computer and your CTRL keys will function once again.  To do this:
1)  Click Start
2)  Control Panel
3)  Printers and Other Hardware
4)  Keyboard
5)  In the Keyboard Properties window, click Hardware
6)  Click Properties
7)  Click Driver
8)  Click Uninstall, click OK
9)  Restart your Computer
900+ people found this answer helpful.
2009-05-13T16:02:40+00:00
Hello nicbar35,
 Thank you for your reply back!
 Is this only happening in Microsoft Word or does this also occur in other programs like 'Notepad"?  I went to Microsoft Word support and am showing commands listed below.  Again, if only happening within Word, I would suggest going to site listed.
Keyboard shortcuts for Word and support:http://office.microsoft.com/en-us/word/HP051866641033.aspx?pid=CH060831551033
Character and paragraph formatting
To do this Press
Copy formatting from text. CTRL+SHIFT+C
Apply copied formatting to text. CTRL+SHIFT+V
James Microsoft Answers Support Engineer Visit our Microsoft Answers Feedback Forum and let us know what you think.
153 additional answers
    2012-07-02T16:24:40+00:00
    Dear ,
    I have some data on my desktop and even in some other folders on my local drives even. I am able to select the item, right click  and copy also. But the content (be it alpha or numeric or a file or an image) is not being pasted either in the mail box, in the local drive (even to a  folder ) etc..
    I am using Windows XP SP3 with Dualcore 2.8, 4Gigs of RAM and 320GB HDD. Please suggest me on this.
    Murthy
    1)  Click Start
    2)  Control Panel
    4)  Keyboard
    6)  Click Properties
    7)  Click Driver
    2012-07-05T16:13:38+00:00
    Try creating a new user account and check if the issue is resolved. This could be a possible fix as it worked for me!
    2012-07-19T15:18:43+00:00
    I have the opposite problem - CTRL-C works CTRL V doesn't. on brand new Dell, having used supplied Transfer program to move over my data from xp  computer. The XP computer had a wireless keyboard/mouse combo that doesn't work on Win7 (at least I can't figure out how), so I used Dell provided keyboard and mouse.
    It only fails in Word 2007, notepad works. I'll do some checking on this
    But...CTRL-V  had been working  in Word 2007 until today when I installed when Windows 7 requested me to run newest update. Could it be something in that update mixed this up?
    Ann
