Ctrl c not working
2009-05-11T08:55:36+00:00
Hello, somehow I have managed to disable the shortcuts for cutting and pasting. I can only do it manually through the menu bar. I cannot Ctrl C or Ctrl V anymore - nothing happens! What have I done? Please help.
thanks
Nicole
(am using Word 2003)
2010-02-03T00:02:47+00:00
Annoying problem if you rely 100% on keyboard shortcuts!  I had the same problem and the fix is very easy.  You will need to uninstall your keyboard driver and restart your computer and your CTRL keys will function once again.  To do this:
1)  Click Start
2)  Control Panel
3)  Printers and Other Hardware
4)  Keyboard
5)  In the Keyboard Properties window, click Hardware
6)  Click Properties
7)  Click Driver
8)  Click Uninstall, click OK
9)  Restart your Computer
900+ people found this answer helpful.
2009-05-13T16:02:40+00:00
Hello nicbar35,
 Thank you for your reply back!
 Is this only happening in Microsoft Word or does this also occur in other programs like 'Notepad"?  I went to Microsoft Word support and am showing commands listed below.  Again, if only happening within Word, I would suggest going to site listed.
Keyboard shortcuts for Word and support:http://office.microsoft.com/en-us/word/HP051866641033.aspx?pid=CH060831551033
Character and paragraph formatting
To do this Press
Copy formatting from text. CTRL+SHIFT+C
Apply copied formatting to text. CTRL+SHIFT+V
James Microsoft Answers Support Engineer Visit our Microsoft Answers Feedback Forum and let us know what you think.
153 additional answers
    2009-05-13T16:17:30+00:00
    Hello Nicbar35,
    Thank you for visiting Microsoft Answers forum.
    Do you have Windows Live Mail client application?
    Martin
    Visit ourMicrosoft Answers Feedback Forumand let us know what you think
    2009-05-13T10:46:09+00:00
    Hi David, thanks for getting back to me. It now appears its only Ctrl C that doesn't work. Ctrl V and Ctrl X works fine. thanks
    2009-05-11T15:38:29+00:00
    Hello, nicbar35
    Thank you for using the Answers Forum!
    Does this just affect Word, or all programs, such as Notepad?
    Did you make any changes recently?
    If this is just affecting Word you may need to go to the following link for additional support: http://www.microsoft.com/office/community/en-us/FlyoutOverview.mspx
    We look forward to hearing back from you.
    David
