USB flash drive prompts with "Write Protected" message.
2010-06-25T00:56:28+00:00
I have recently purchased a 32gb usb flash drive. I have been using it ok until 3 days ago. I now get a message saying "Write Protected". There is no write protection switch on the device. How do i remove the write protection.
2010-06-25T21:03:53+00:00
You can remove write protection from your usb flash drive using the below method:
a. Open start menu, in the search bar type regedit and press enter. This wil open the registry editor.
b. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note:
If the registry key StorageDevicePolicies does not exist, you will need to create it manually.
c. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
d. Double click the key WriteProtect in the right window and set the value to 0 in the Value
Data Box and press OK button
e. Restart your computer and try copying files into your USB drives.
Important Note:
Sometimes this problem is caused by two Windows registry entries that have become corrupted. To fix the problem, you have to use Registry Editor to delete the corrupted registry entries.
However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs.
For more information about how to back up and restore the registry, follow the steps as in the KB Article:
http://support.microsoft.com/kb/322756/
Hope this helps.
Thanks and Regards:
Shekhar S - Microsoft Support. Visit our Microsoft Answers Feedback Forum and let us know what you think.
If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.
66 additional answers
    2013-03-27T11:26:41+00:00
    Hi, im trying to fix a usb device as well. The only problem is that "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control" no version of this directory exists on my computer. I'm using a windows 7 64bit Dell.
    It just says windows cannot find... (the above directory)
    Any assistance would be great. Cheers****
    It's not a directory.  Windows Explorer will not find it.
    You need to run regedit.exe to create a registry key, but if you don't know what you're doing, be careful.
    Backup the Registry first.  Then press the "Windows" key on your keyboard and type regedit (don't need to click in the box) and press Return.
    Navigate to CurrentControlSet\Control and right click the panel to create a new key, as described in an earlier post.
    You should note that this does not work with some damaged drives, where the file system is corrupted, because Windows cannot 'see' the drive.
    2013-03-27T11:28:52+00:00
    Sorry - should have also given you instructions to backup the Registry!
    Look here - Windows Support
    BB
    2013-03-28T09:19:49+00:00
    The solution is actually simple..
    c. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect."
    then set the value to 0
    this worked for me.
    2013-03-28T09:34:38+00:00
    this worked for me.
    As I pointed out in my post above, you can create a new DWORD, but I'm afraid that only works if the problem is in the Registry system security policies.
    I've tried all the known solutions, including trying to fornmat in Linux:
    fdisk /dev/sda
    mkfs -t vfat /dev/sda1I was issuing these with data for my students, but four of the twenty five are still not usable and cannot be recovered.  I think the waste bin will be their next home.
