Volume icon disappeared from my system tray, and the option is greyed out (won't let me check it) in the taskbar and start menu properties screen /Notification area
2010-04-21T14:17:02+00:00
I don't know how to get my volume icon back - can anyone help?  Thank you!
2010-04-21T16:39:22+00:00
 If any of the system icons are out, you can re-enable them as follows:
Right click on the taskbar and select properties. This will bring up the "Taskbar and start menu properties" tab. This is where you mentioned it was greyed out. That's fine...  From here you can click on customize button in the icons section. Locate the icon that you are missing and check status. The status type should read "Hide  icon and notifications", change this to "Show icon and notifications".
If this doesn't fix the issue you most likely have an issue with a group policy on your machine. This can be fixed by following the instructions on the following link:
http://www.mydigitallife.info/2009/01/01/fix-network-clock-volume-and-power-battery-system-icons-missing-with-disabled-or-grayed-out-check-box-options/
Hope this helps,
Steve <> Microsoft Partner
104 additional answers
    2015-10-03T23:30:25+00:00
    These are the worse Instructions ever!
    2015-10-05T15:36:07+00:00
    This should help,
    Right click the task bar and then click task manager and then click the processes tab then fine 'EXPLORER.EXE'  then end process then you task bar should disappear after that click on the applications tab and then 'new task...' and type 'EXPLORER.EXE' it should appear
    good luck :)
    This worked for me. Thanks
    This was quick and effective! Thank you. Thank you!
    2015-10-15T17:06:54+00:00
    I was looking for a solution and this helped, thank you for your help.
    2015-11-02T22:05:26+00:00
    Honestly, just restart explorer.exe by going into Task Manager (Ctrl+Shift+Esc) and finding Windows Explorer and and hitting Restart in the bottom right. If that dosen't work, follow what Fixer Upper said.
    (This is for people who might need to do it quickly or don't know how to do it since they have Win 10.)
