How to extend system drive partition (C:) to get more capacity
2010-01-30T05:28:57+00:00
After installing Win 7 on C: with other programs that partition is getting too close to full.  How do I add from logical partition to increase size of c:?
2010-01-30T20:28:34+00:00
When you are unable to make changes to partitions using Disk Management below are partitioning programs you can use.
EASEUS Partition Master (free):
Includes Partition Manager, Disk & Partition Copy Wizard and Partition Recovery Wizard for Windows XP/Vista/Windows 7 (32 bit and 64 bit). It allows users to Resize/Move Partition, Extend System Drive, Copy Disk & Partition, Merge Partition, Split Partition, Redistribute Free Space, Convert Dynamic Disk, Partition Recovery and more. Be careful, re-sizing partitions is usually safe but errors can happen, and always backup anything important before modifying partitions on your hard drive.
http://www.partition-tool.com/personal.htm
Paragon Partition Manager (free):
A good program for making general changes to hard drive partitions while Windows is running. Create, delete, format, and resize partitions with this program. It can also defragment, check file system integrity, and more. Be careful, re-sizing partitions is usually safe but errors can happen, and always backup anything important before modifying partitions on your hard drive.
http://www.paragon-software.com/home/pm-express/download.html
Gparted Boot Disk(free):
If you can't make the changes you want with Windows running using a Gparted boot disk to change the partitions is a good solution. If you will be changing the main Windows partition, or a partition with important info, backup anything important - it's not common, but things can go wrong. Altering the partitions can be risky, be careful and know what you are doing - there is no Windows safety option when using this - if you tell it to format the Windows partition it will do so and delete the entire Windows installation. Depending on what you are doing it can take from a few minutes to a couple hours. Download the ISO and burn it to a CD.
http://sourceforge.net/projects/gparted/files/gparted-live-stable
How to use:
http://www.dedoimedo.com/computers/gparted.html
If after altering the partitions Windows 7 data/files are still there but Windows won't boot the following may help:
Try Repairing The Windows 7 Installation
  1. Insert the Windows 7 DVD and restart your computer
  2. Boot from the DVD.
  3. Choose your language and click Next.
  4. Click Repair Your Computer and then select the operating system you want to repair.
  5. Click on the Startup Repair link from list of recovery tools in System Recovery Options.
If that doesn't fix it:
  2. Boot from the DVD. If prompted, press any key to start Windows from the installation disc.
  5. Select Command Prompt and try the following commands (a single command might work, or you may need to use multiple commands depending on the exact problem):
bootrec /fixMBR
bootrec /fixBoot
bootrec /rebuildBCD
Note: there is a space before the /
Have Questions About Installing Windows 7?
FAQ - Common Windows 7 Installation Questions & Answers
71 additional answers
  1. Deleted
    2012-03-03T22:59:39+00:00
    This solved my problem.
    I move the unallocated space from behind D drive to infront D drive and C drive became extendable !
    Can you please explain to me how I do that
    2012-03-04T00:38:10+00:00
    This thread was originally created in the Hardware and Drivers forum.  The Microsoft Answers Moderation team has moved it to the Performance and Maintenance forum.  Thanks.
    2012-04-19T03:55:31+00:00
    Saryli, thank you for posting the tool, I just did a fresh install of Windows 7 Pro on a PC that was Linux. Tool worked just fine.
