Keep Num Lock on after start-up
2008-12-22T16:09:28+00:00
How do I make windows start-up with the Number Lock on?
2008-12-22T19:42:50+00:00
Windows will remember the setting you use at shutdown, usually. If you have trouble with that, there is a registry setting you can make to do it. If you are comfortable with that, for now you can go to :
HKEY_CURRENT_USER\Control Panel\Keyboard] (or [HKEY_USERS.DEFAULT\Control Panel\Keyboard] for all users) "InitialKeyboardIndicators"="2"
Later, you can come back to this thread when the "FitIt4me" team has the button developed to do that for you. They should be finishing up development work on that pretty soon.
Mark L. Ferguson MS-MVP
61 additional answers
    2010-03-12T05:19:07+00:00
    Those numbers indicate that Caps Lock is the second bit in a flags
    structure, ie 2^1 (which equals 2 if you remember from school).
    2^0 =1
    2^1 =2
    2^2 =4
    The official documentation for decades say 0 and 2 are the only values.
    "Saint_Bernard" wrote in message
    news:36a93b1b-d242-4004-a00f-07588ffbf6a3...
    >I propose a challenge. I tested all of the numbers from zero to seven in
    >the 'InitialKeyboardIndicators' registry. First I locked each value; then I
    >did not lock the values. It is my opinion that Windows 7 has a bug --
    >actually several but I shall only discuss one of them here. I challenge
    >anyone out there to prove to me that the results I am about to produce do
    >NOT indicate the existance of a bug in Windows 7. As my reference point I
    >am using: http://www.tipstrs.com/tip/2776/Boot-with-the-Num-Lock-enabled
    > I assigned the 'InitialKeyboardIndicators' key every single value, and
    > tested each value in two states: Num Lock On and Num Lock Off. When I
    > locked each value my results where as follows: 0 - Off, 1 - Off, 2 - On,
    > 3 - On, 4 - Off, 5 - Off, 6 - On, and 7 - On. NO OTHER KEY'S STATE WAS
    > AFFECTED! Granted, there is a pattern but why was ONLY the status of the
    > 'Num Lock' affected? Correct me if I am wrong but would it not make more
    > sense to have the indicator values produce the same results as in the
    > website I have referred to in the preceding paragraph?
    > When I did not lock the values zero to seven Windows 7 ALWAYS REPLACED MY
    > VALUE WITH A VALUE OF TWO! Now, according to the preceding paragraph a
    > value of '2' should turn the 'Num Lock' state 'On' but once again either I
    > can no longer think straight because it is 3:30 a.m. and I have been up
    > since 7:00 a.m. or Windows 7 HAS A BUG because THIS WAS NOT THE CASE!
    > Every single value left the 'Num Lock' status unchanged! Goodnight, and I
    > wish I could say good riddens to Microsoft...
    > Programmer for Visual C++ 6.0, and Microsoft Office including Access
    2010-03-13T17:10:15+00:00
    So, basically you are saying that the website I have alluded to is completely inaccurate.
    As far as binary numbers are concerned, what are the following binary numbers: 0001, 0011, 0101, 0111?
    As far as having the second bit set the CAPS LOCK is concerned, have you ACTUALLY TRIED IT or are you just copying some out-dated documentation?
    Have you even read what I wrote? I was present when someone from IBM set the 'second' flag and this did NOT set the state of the CAPS LOCK key. Furthermore as per my above posting I physically tried every single value from '0' to '7' and a value of '2' did NOT SET THE CAPS LOCK (By the way, two is 2^1 just like you stated.) Furthermore when I did not lock the value Windows 7 ALWAYS reset it two '2.' Does that adhere to your 'documentation'? When I restarted my computer WITHOUT altering the value of '2' placed into the registry position the CAPS LOCK was NOT SET as per your posting.
    You see, in some companies the technical writers are unable to test what they write because the product they are discussing is not even in existence. Someone tells them how they believe it 'should' work and they have no way of testing what they are writing. When they complete the documentation someone stamps the word 'official' on the document. In other words, stamping a document as being 'official' does NOT mean it is 'correct.'
    2010-03-14T18:38:30+00:00
    I have tried every thing that is in this forum. Not one of them worked. I have a HP Pavilion 2170us Laptop Vista Home Premium 64.bit OS  factory installed. I have upgraded to Windows 7 Pro. The way that I was able to keep the numlock on at boot up was to use Windows easy transfer to transfer the system settings from my HP Desktop which just happens to be a Windows 7 Pro that had been a XP OP 32bit from the factory. I just transfered the system settings. I not sure what changed as I looked in the registry and all keyboard settings are the same. But I now have number lock on at startup.
    2010-03-14T18:43:25+00:00
    Also it doesn't matter if the old system is running Vista XP or Windows 7 as I upgraded another PC from XP to Windows 7 used easy transfer and num lock stayed on. Thats where I got the idea.
