Keep Num Lock on after start-up
2008-12-22T16:09:28+00:00
How do I make windows start-up with the Number Lock on?
2008-12-22T19:42:50+00:00
Windows will remember the setting you use at shutdown, usually. If you have trouble with that, there is a registry setting you can make to do it. If you are comfortable with that, for now you can go to :
HKEY_CURRENT_USER\Control Panel\Keyboard] (or [HKEY_USERS.DEFAULT\Control Panel\Keyboard] for all users) "InitialKeyboardIndicators"="2"
Later, you can come back to this thread when the "FitIt4me" team has the button developed to do that for you. They should be finishing up development work on that pretty soon.
Mark L. Ferguson MS-MVP
61 additional answers
    2017-11-25T03:37:10+00:00
    How to keep number lock for windows phone
