Keep Num Lock on after start-up
2008-12-22T16:09:28+00:00
How do I make windows start-up with the Number Lock on?
2008-12-22T19:42:50+00:00
Windows will remember the setting you use at shutdown, usually. If you have trouble with that, there is a registry setting you can make to do it. If you are comfortable with that, for now you can go to :
HKEY_CURRENT_USER\Control Panel\Keyboard] (or [HKEY_USERS.DEFAULT\Control Panel\Keyboard] for all users) "InitialKeyboardIndicators"="2"
Later, you can come back to this thread when the "FitIt4me" team has the button developed to do that for you. They should be finishing up development work on that pretty soon.
Mark L. Ferguson MS-MVP
61 additional answers
    2016-02-03T22:21:39+00:00
    in Regedit:
    1.  HKEY_USERS.DEFAULT\CONTROL PANEL\KEYBOARD
    2.  INITIALKEYBOARDINDICATIORS
    3.  IF VALUE IS 2147483648
       CHANGE TO 2147483650
     This fixed my problem after upgrading to Win.
    JohnWilliam1985 - definitely best answer!!!!  It took me a total of 15 seconds to make the change then whatever time to reboot because I couldn't wait until later to find out if it worked or not (Win 7).  Of course it did.  I went straight to my laptop that has Win 8.1 on it and did the same (I use a traditional keyboard when I'm stationary for long periods of time) - kudos again!!!
    Thank you. ;)
    2016-09-02T16:46:13+00:00
    Do you have a fix for windows or will this work just asking?
    2016-09-02T19:24:22+00:00
    Download a simple utility called Numlocker. http://numlocker.en.softonic.com/
    I have used it for many years without issue, currently with Windows 10. Now, I never have to press the 'NumLock' key -- ever!
    It does the required registry change for you.
    2017-11-20T16:34:47+00:00
    I don't know how to do what you suggest above.
