Is Remember each folder's view settings functionality gone for good?
2009-10-04T19:26:27+00:00
Everyone remembers this from Windows XP. You goto My Computer/Tools/Folder Options.../View and there used to be a check box for "Remember each folder's view settings"
Is it going to be incorporated into Windows 7 anytime soon?
The main reason why I like it is I want my music folder to always open as simply as possible, with just a list of bands so it ends up being a really thin long window.. it works rather well. Windows 7 has completely lost the capabilities of doing this. I really don't want to have to resort to a 3rd part app.. please tell me it's being worked on... anyone?
2011-05-18T16:32:58+00:00
HI,
I have been searching for a solution for about 2 weeks and nothing has worked so far!!
Last night I think i found a workaround.  If you want your folders to keep its view settings then you MUST NOT USE THE LIBRARY folders to view!!!!  the reason for this is because, Libraries let you access and arrange items from one or more folders quickly without moving them from their original location. Libraries themselves don't store your files or folders. Instead, they point to different locations on a hard disk or external drive attached to your computer.
So, now that we now that we can try the workaround I did and is working fine for me.
1.  go to start - and click your username that is all the way on the right hand corner.
2.  go to tools - folder options - in general tab got to be bottom and click " show all folders"
3.  now you will see your "Username" folder appear underneath "library".   If you expand that folder (username folder)  you will see your documents folders, pictures folders, music folders and ect.
4.  open any folder you want and customizes the view as you wish. You can do this to every folder !! and it will keep its view settings.
This is worked for me!!!   I DO NOT USE THE FOLDERS UNDER LIBRARY BECAUSE THEY WILL NOT KEEP THERE SETTINGS!!! SO I JUST CLOSE THE LIBRARY AND KEEP ONLY EXPANDED MY USERNAME AND ALL FOLDERS UNDER IT.
HOPE THIS HELPS..... PLEASE LET ME KNOW IF IT WORKED AND IF YOU HAVE ANY OTHER BETTER WAY OF HELPING.
2012-02-20T00:29:09+00:00
The path Windows 7 Home Premium on my Win7 for Quick Launch is located...
is Roaming \ Microsoft \ Internet Explorer
C:\Users\Your Username\AppData\Roaming\Microsoft\Internet Explorer
Other's listed under Users are as follows
C:\Users\Your Username\AppData\Local\Microsoft\Internet Explore
Quick Launch, not shown
iconcache
IECompatData
Recovery
Within LocalLow \ Microsoft \ Internet Explorer
C:\Users\Your Username\AppData\LocalLow\Microsoft\Internet Explorer
iconcache
Services
Thank you very much marwerno, now the only problem is the Quick Launch is on the Right next to the Tray.  Which 4 icons and the Clock, I can click on the Show Desktop that came pre-installed as is.  And far as I know it cannot be moved.
On Vista, its on the left near Start, which Quick Launch is an option of Taskbar and Start Menu Properties under Tab Toolbars, which is checked.  However, no option to select on the Left or Right.  So a User has no control of where Taskbar features can be placed,
Start > Settings > Taskbar and Start Menu > Toolbars
Too bad Microsoft could of not left this Feature/Option alone.  And with Win7, Start > Right click the Right Column gray area and Select Properties > Toolbars > Quick Launch
However, this is only because of  Start/Toobar, Right click -> Toolbars -> New Toolbar-Choose a folder by going to C:\Users\Your Username\AppData\Roaming\Microsoft\Internet Explorer and Select Quick Launch
If you de-select Quick Launch (Win7) Start > Right click the Right Column gray area and Select Properties > Toolbars > Quick Launch
That Option is now gone and you have to repeat the process you mentioned.
Some things are better if left alone, one option Show Desktop, changed from XP to Vista to Win7...sorry no logic in the differences as being better, just more annoying.
And I do use XP Pro, Vista and Win7 Home Premium is primary, sometimes daily and I also run Win7 Pro.  And I have 3 older computers that have installed and Run DOS 6.2, 95, 98, ME, 2000, using a 4-Port KVM Switch and using the old PartitionMagic software
As I have an original $2000 Flatbed Scanner with Transparency Adapter from 1994, that uses a SCSI card.  And other antiquated Software dating back the 1980's.  I finally parted with my PC's using 5.25 Floppies and tossed those Disks.
Thanks again, I appreciate your time and suggestion...Doc - drdocyoung.com
@CmdrKeene 90,631 Reputation points Volunteer Moderator
2010-03-20T22:05:37+00:00
It's not something that's "broken", Microsoft built it this way on purpose.  So I wouldn't expect to see a "fix" for it until Windows 8 -- because they don't change features in updates, only in new versions.
If you want to voice your feedback, http://mymfe.microsoft.com/Windows%207/Feedback.aspx?formID=195
As you can see in this picture below, Microsoft made this change intentionally, so I don't believe you'll see a update to change it until the next version of Windows, because they don't change features during updates:
If this was helpful, please vote by clicking the green triangle. If it solves the issue, click Propose as Answer. Thanks!
2009-10-04T22:39:57+00:00
Default behavior. It is not possible to set Windows Explorer to remember individual folder view settings for folders included in libraries. All libraries and its included folders share the same view.
Andre Da Costa http://adacosta.spaces.live.com http://www.activewin.com
259 additional answers
    2009-12-24T21:22:24+00:00
    Hi Guys.
    There is two scenarios with remembering views (Windows 7):
    1. Libraries - Don't Remember
    2. Folders / Favourites - DO Remember (Easy Fix : Add My Docs to Favourites - see below)
    Library Behaviour
    Lets say you click Documents, then choose 'medium icons', wherever you navigate within Documents from then on stays in 'med icon' view.
    NB Choosing Organize>Fold & Search Options>View>'Apply to Folders' and 'Reset Folders'are not available in Libraries.
    Folders do remember views by default. So if you navigate to C:\users\xxx\Documents etc each individual folder in the tree will remember whatever you set it to.
    Likewise if you add 'My Documents' to Favourites and navigate from there. To add 'My Docs' to Favourites you need to navigate to your User Folder e.g:
    i)Start Menu> User Folder> My Docs
    ii) Rt-click 'Favourites' > 'Add current location to favourites'
    DO NOT add 'My Docs' to Favourites from within Libraries. As it is  'Libraries' that ignore last view setting.
    NB Choosing Organize>Fold & Search Options>View>'Apply to Folders' and 'Reset Folders' are available in Folders. So you can make all folders copy your current view (Apply to folders).
    Hope this helps.
    Gray
    THANK YOU Gray! I don't think people are reading you post, because if they did they would see that you have the REAL answer. I won't hold it against you that you spell "Favorites" wrong. ;-)
    The lost feature is in Win7 Libraries, but not in the "real" folders. You can "approach" the same folder from Libraries or from a non-library path (root, Favorites, etc.). As long as you avoid the Library path the folder settings will stay.
    I suppose MS doesn't want to admit there are problems with its new Library feature.
    Eric
