power icon from the task bar is missing
2009-10-16T23:06:37+00:00
I haven't notice this untill now and when I went too power options I can't see the icon if you wanna select.. So I went too notification area and click system icons on or off I see them all on but power it's faded like you can't click on or off and it's greyed off.
2009-10-18T14:43:07+00:00
KeithVenable,
Please perform the following steps:
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
http://support.microsoft.com/kb/322756/ - How to back up and restore the registry in Windows
  1. Click Start.
In the Start Search field, type regedit.exe and then press Enter.
If you are prompted for an administrator password or for confirmation, type the password, or click Allow. 2. Locate and then click the following registry subkey:
HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\TrayNotify 3. In the Details pane, click the IconStreams registry entry. 4. On the Edit menu, click Delete, and then click Yes. 5. In the Details pane, click the PastIconsStream registry entry. 6. On the Edit menu, click Delete, and then click Yes. 7. Exit Registry Editor. 8. Restart the Explorer.exe process. To do these, follow these steps: 1. Press CTRL+SHIFT+ESC. 2. On the Processes tab in Task Manager, click the explorer.exe process, and then click End Process two times. 3. On the File menu, click New Tasks (Run), type explorer, and then click OK. 4. Exit Task Manager. 9. Once Explorer.exe has restarted, right click on the clock and choose "Customize Notification Icons". 10. Ensure that Power is set to "Show icon and notifications". 11. Click on "Turn system icons on or off" 12. Ensure that Power is set to "On". 13. Click on OK and close the Control Panel.
Hope that helps, have a great day!
Kristan M. Kenney ("Nighthawk64") | My Blog: http://blog.kristankenney.com
2009-10-17T16:39:19+00:00
Hi KeithVenable,
Check boxes may be disabled and greyed out probably due to third party drivers that want to show manufacturer’s icon instead.
You can go to the link mentioned below and run “Fix it”.
http://support.microsoft.com/kb/945011
After the process is complete, please restart your computer and enable the power option in notification area.
You can refer the following link for more information:
 http://social.technet.microsoft.com/forums/en-US/itprovistasp/thread/7712e102-98ee-4dc7-95bd-ad2d33d2e26d/
Hope this helps.
Regard,
Sujan – Microsoft Support
83 additional answers
    2012-03-29T11:50:57+00:00
    Hi Job,
    This is a new computer build.  The power icon never appeared and was always grayed out.
    Gigabyte Z68
    Intel 2500K
    Windows 7 professional 64
    Administrator account.
    I followed Method 1 and there were no files which needed to be replaced.
    I followed Method 2 and the power icon and action center icons were grayed out.
    When I booted up this morning (prior to running the Methods above) my action center icon was not grayed out.
    After I followed the Methods and returned to my account, the action center icon was also grayed out.
    Thanks for your help.
    Chris
    2012-04-11T05:41:02+00:00
    I'm running Windows 7 64bit Home Premium
    I performed all these steps (that BTW are detailed in a Microsoft KB article) and it helped clean up old junk but didn't restore the Power icon. I also run the Microsoft Fix-it program.
    I found the problem was a driver from an APC UPS. I went to batteries in device manager and uninstalled the entry for the third party device. I took the precaution of first finding out what the .inf file was (you can find this in the details section of the device properties under inf name). Again being carefull I didn't check the delete driver file from the uninstall pop-up, I just renamed the inf file(s) in the Windows\inf directory. This did the trick after restart!. The power icon showed up again and now Windows was effectivelly managing the power as in the batteries section of the device manager the APC device was replaced by a HID UPS entry which uses the Windows battery.inf file.
    2012-09-28T16:26:36+00:00
    explorer.exe is not appearing once I've click Ctrl+Shift+Esc. How could this be? please help me!!!!!!!!!!1
