power icon from the task bar is missing
2009-10-16T23:06:37+00:00
I haven't notice this untill now and when I went too power options I can't see the icon if you wanna select.. So I went too notification area and click system icons on or off I see them all on but power it's faded like you can't click on or off and it's greyed off.
2009-10-18T14:43:07+00:00
KeithVenable,
Please perform the following steps:
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
http://support.microsoft.com/kb/322756/ - How to back up and restore the registry in Windows
  1. Click Start.
In the Start Search field, type regedit.exe and then press Enter.
If you are prompted for an administrator password or for confirmation, type the password, or click Allow. 2. Locate and then click the following registry subkey:
HKEY_CURRENT_USER\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\TrayNotify 3. In the Details pane, click the IconStreams registry entry. 4. On the Edit menu, click Delete, and then click Yes. 5. In the Details pane, click the PastIconsStream registry entry. 6. On the Edit menu, click Delete, and then click Yes. 7. Exit Registry Editor. 8. Restart the Explorer.exe process. To do these, follow these steps: 1. Press CTRL+SHIFT+ESC. 2. On the Processes tab in Task Manager, click the explorer.exe process, and then click End Process two times. 3. On the File menu, click New Tasks (Run), type explorer, and then click OK. 4. Exit Task Manager. 9. Once Explorer.exe has restarted, right click on the clock and choose "Customize Notification Icons". 10. Ensure that Power is set to "Show icon and notifications". 11. Click on "Turn system icons on or off" 12. Ensure that Power is set to "On". 13. Click on OK and close the Control Panel.
Hope that helps, have a great day!
Kristan M. Kenney ("Nighthawk64") | My Blog: http://blog.kristankenney.com
2009-10-17T16:39:19+00:00
Hi KeithVenable,
Check boxes may be disabled and greyed out probably due to third party drivers that want to show manufacturer’s icon instead.
You can go to the link mentioned below and run “Fix it”.
http://support.microsoft.com/kb/945011
After the process is complete, please restart your computer and enable the power option in notification area.
You can refer the following link for more information:
 http://social.technet.microsoft.com/forums/en-US/itprovistasp/thread/7712e102-98ee-4dc7-95bd-ad2d33d2e26d/
Hope this helps.
Regard,
Sujan – Microsoft Support
83 additional answers
    2010-11-04T06:28:12+00:00
    I got an account just so I could come on and thank you.
    So...Thank you Kristan! I followed your advice and it totally worked.
    2010-11-14T22:24:29+00:00
    This fixed a long-standing issue I've been having with my laptop ever since I upgraded from XP to Win 7 - superb!   The only system icon I could access was the clock, but this fixed it so now I can see my battery, volume, and network.
    2011-03-20T02:58:29+00:00
    I've tried all the things listed here and I'm still having no luck.  The "system icon" is grayed out and shows to be "off".
    I've removed the battery.  I've deleted the registry files.  I've tried the "fix-it"....still no luck.  I have an Asus laptop with Windows 7 Home Premium.
    Are there any other suggestions?
    Randy
