Is there any way to make a desktop shortcut for the sleep command?
2009-01-10T03:57:52+00:00
Desktop shortcut for the sleep command?
Is there any way to make a desktop shortcut for the sleep command? I can't find the actual location that the sleep button on the start menu points to. It has to point somewhere! Please, if anyone knows how i can create this shortcut, help!!! Thanks a bunch!
2009-01-10T12:18:27+00:00
Tar-ter,
To create a shortcut that will execute the sleep command in Vista:
  • Right Click in the desired location (On the Desktop or in a folder)
  • Select New -> Shortcut
  • In the “Type the location of the item” field enter the following
  • Rundll32.exe Powrprof.dll,SetSuspendState Sleep
  • Click Next
  • This will create a shortcut with the name rundll32,
  • Right Click the shortcut, select Rename and type in Sleep
**** You can now open this shortcut whenever you desire to put your computer into sleep mode.
Note: You can replace the default icon with a Shutdown one by:
  • Right Click the created shortcut, select Properties -> Change Icon
  • Navigate to this link in the **“**Look for icons in this file:” field:
  • %SystemRoot%\system32\SHELL32.dll icons
  • Find the desired icon.
  • Click Ok.
Thank you for using the Microsoft Vista Support Community.
Rami
73 additional answers
    2010-05-21T14:57:01+00:00
    This is NOT a solution for everyone.  I have a brand new Acer desktop computer running Win 7 Home Premium that does not yet have any extra software installed.  Like many others, the menu sleep button works fine, but any attempt to crate a sleep command or batch file only results in hibernation.  Even surloc's bat file (which I did copy/paste, so I KNOW it wasn't mistyped) results in nothing but hibernation.  Sure would be nice to actually have a solution from MS on this.
    2010-07-11T13:13:05+00:00
    V7Goose, did you try running the script as administrator? That did the trick for me.
    2010-09-15T03:38:47+00:00
    Me too. But now I'm getting a UAC popup every time I try to sleep. Ugh.
    2010-11-13T01:30:51+00:00
    surloc, PERFECT! thanks so much. it took me a week to figure it out, nothing worked before. you rock!
