Is there any way to make a desktop shortcut for the sleep command?
2009-01-10T03:57:52+00:00
Desktop shortcut for the sleep command?
Is there any way to make a desktop shortcut for the sleep command? I can't find the actual location that the sleep button on the start menu points to. It has to point somewhere! Please, if anyone knows how i can create this shortcut, help!!! Thanks a bunch!
2009-01-10T12:18:27+00:00
Tar-ter,
To create a shortcut that will execute the sleep command in Vista:
  • Right Click in the desired location (On the Desktop or in a folder)
  • Select New -> Shortcut
  • In the “Type the location of the item” field enter the following
  • Rundll32.exe Powrprof.dll,SetSuspendState Sleep
  • Click Next
  • This will create a shortcut with the name rundll32,
  • Right Click the shortcut, select Rename and type in Sleep
**** You can now open this shortcut whenever you desire to put your computer into sleep mode.
Note: You can replace the default icon with a Shutdown one by:
  • Right Click the created shortcut, select Properties -> Change Icon
  • Navigate to this link in the **“**Look for icons in this file:” field:
  • %SystemRoot%\system32\SHELL32.dll icons
  • Find the desired icon.
  • Click Ok.
Thank you for using the Microsoft Vista Support Community.
Rami
73 additional answers
    2010-03-11T00:29:57+00:00
    I'm also having the problem of issuing a sleep with the command Rami provided. It always hibernates, never sleeps, yet it will sleep when chosen from the shutdown menu. Tried it on a Dell laptop running windows 7, and windows x86 2008 server. My main focus is the server, which I'd like to put to get to hybrid sleep by a script when it detects no one is logged in. What gives? This shouldn't be so hard!
    Anyone? Anyone?
    2010-04-08T10:34:07+00:00
    Create a batch file with the following:
    @echo off
    powercfg -h off
    rundll32.exe powrprof.dll,SetSuspendState 0,1,0
    powercfg -h on
    Then create the desktop shortcut and use the Browse to point to the batch file you created. Works perfectly.
    2010-05-08T19:33:24+00:00
    Surloc THAT WORKS AWESOME!!! Finally an answer to this puzzling situation.  Thank you!
    2010-05-15T22:38:38+00:00
    It was really very nice the way Rami and Microsoft Support managed to ignore giving an answer to this problem for 4 months to those of us with "Hybrid Sleep" enabled on our computer.
    Thank you user surloc !!!  You gave us the simple answer that we were all looking for and that Microsoft never provided. You solution works perfectly! Thanks a million to surloc, no thanks to Microsoft's  Support engineers.
