Is there any way to make a desktop shortcut for the sleep command?
2009-01-10T03:57:52+00:00
Desktop shortcut for the sleep command?
Is there any way to make a desktop shortcut for the sleep command? I can't find the actual location that the sleep button on the start menu points to. It has to point somewhere! Please, if anyone knows how i can create this shortcut, help!!! Thanks a bunch!
2009-01-10T12:18:27+00:00
Tar-ter,
To create a shortcut that will execute the sleep command in Vista:
  • Right Click in the desired location (On the Desktop or in a folder)
  • Select New -> Shortcut
  • In the “Type the location of the item” field enter the following
  • Rundll32.exe Powrprof.dll,SetSuspendState Sleep
  • Click Next
  • This will create a shortcut with the name rundll32,
  • Right Click the shortcut, select Rename and type in Sleep
**** You can now open this shortcut whenever you desire to put your computer into sleep mode.
Note: You can replace the default icon with a Shutdown one by:
  • Right Click the created shortcut, select Properties -> Change Icon
  • Navigate to this link in the **“**Look for icons in this file:” field:
  • %SystemRoot%\system32\SHELL32.dll icons
  • Find the desired icon.
  • Click Ok.
Thank you for using the Microsoft Vista Support Community.
Rami
73 additional answers
    2016-12-29T23:38:58+00:00
    If anyone is looking to perform the 'sleep' function on a Dell Venue 8 Pro Windows 8.1 tablet, here is the solution that worked for me:
    https://www.eightforums.com/drivers-hardware/51756-create-sleep-button-shortcut-desktop-3.html
