Is there any way to make a desktop shortcut for the sleep command?
2009-01-10T03:57:52+00:00
Desktop shortcut for the sleep command?
Is there any way to make a desktop shortcut for the sleep command? I can't find the actual location that the sleep button on the start menu points to. It has to point somewhere! Please, if anyone knows how i can create this shortcut, help!!! Thanks a bunch!
2009-01-10T12:18:27+00:00
Tar-ter,
To create a shortcut that will execute the sleep command in Vista:
  • Right Click in the desired location (On the Desktop or in a folder)
  • Select New -> Shortcut
  • In the “Type the location of the item” field enter the following
  • Rundll32.exe Powrprof.dll,SetSuspendState Sleep
  • Click Next
  • This will create a shortcut with the name rundll32,
  • Right Click the shortcut, select Rename and type in Sleep
**** You can now open this shortcut whenever you desire to put your computer into sleep mode.
Note: You can replace the default icon with a Shutdown one by:
  • Right Click the created shortcut, select Properties -> Change Icon
  • Navigate to this link in the **“**Look for icons in this file:” field:
  • %SystemRoot%\system32\SHELL32.dll icons
  • Find the desired icon.
  • Click Ok.
Thank you for using the Microsoft Vista Support Community.
Rami
73 additional answers
    2016-03-19T05:41:43+00:00
    The following sleep states are available on this system:
        Standby (S3)
        Hibernate
        Hybrid Sleep
        Fast Startup
    The following sleep states are not available on this system:
        Standby (S1)
            The system firmware does not support this standby state.
        Standby (S2)
        Standby (S0 Low Power Idle)
    2016-05-17T10:59:29+00:00
    Works!  Thanks.
    2016-05-17T11:12:25+00:00
    Works!  Thanks.
    Hmmm, it worked first time, then hibernated.
    2016-08-24T13:24:57+00:00
    Click on any empty space on your desktop, and then press [ALT]+[F4] on your keyboard.
    This will bring up the Sleep dialog.
