Cannot delete system volume information folder on windows 7 !?!
2009-10-13T17:09:49+00:00
I cannot delete system volume information folder in D:/ E:/ on windows 7
I took ownership as admin on the folder but I cannot delete it completely!
I run an elevated command prompt and deleted some files in it but cannot remove the folder!
In vista I could mange to delete it after taking ownership on the folder by pressing del the folder will go away!
any ideas?
don`t ask me why I am trying to remove the folder pls...i just need to
thank you
2010-12-12T23:38:51+00:00
Old post I know but I've had this problem on several of my removeable HDs and finally I managed to remove the 'System Volume Information' folder:
DO NOT DO THIS ON YOUR C: OR YOUR WINDOWS HARDDRIVE!!!!!
Right click desktop and click [New->Shortcut]
Write: cmd.exe
Click [Next] then [Finish]
Right click the cmd.exe icon and click 'Run As Adminstrator"
Now select the external hard drive (F: in my case)
C:>f:
Now do the following (you can copy paste):
F:>attrib -s -h /S /D
F:>attrib -r /S /D
F:>rd "System Volume Information" /S
System Volume Information, Are you sure (Y/N)? y
And you're DONE ;-)
53 additional answers
    2013-04-13T03:06:51+00:00
    Thanks for all the input.  If there is no reason to get rid of the SVI, then I am happy to keep it.  My challenge is that is causes very high disk usage which impairs the rest of the system.  It does seem to mellow out after a couple of hours but will start back up again once I start using the computer.  Any thoughts?
    S/F DD83
    2013-04-16T12:33:17+00:00
    Do folder is created system volume information after formate process directly, "or is it arises thereafter up to day?
    2013-04-29T01:25:31+00:00
    Sorry, was on the road.  Not sure when it was created but it took several months before I noticed the issue, probably about six months.
    2013-04-29T09:37:28+00:00
    I would not expect any noticeable activity being generated from the contents of the SVI folder. You can get infected restore points.
    Boot the computer to safe mode with networking and download and install Malwarebytes (freeware version for home users only), update definitions and run in safe mode. Disable other security software whilst you are doing scans.
    http://www.computerhope.com/issues/chsafe.htm
    http://www.malwarebytes.org/products/malwarebytes\_free
    Download and run SuperAntiSpyware (Free Edition)
    http://www.superantispyware.com/download.html
