Cannot delete system volume information folder on windows 7 !?!
2009-10-13T17:09:49+00:00
I cannot delete system volume information folder in D:/ E:/ on windows 7
I took ownership as admin on the folder but I cannot delete it completely!
I run an elevated command prompt and deleted some files in it but cannot remove the folder!
In vista I could mange to delete it after taking ownership on the folder by pressing del the folder will go away!
any ideas?
don`t ask me why I am trying to remove the folder pls...i just need to
thank you
2010-12-12T23:38:51+00:00
Old post I know but I've had this problem on several of my removeable HDs and finally I managed to remove the 'System Volume Information' folder:
DO NOT DO THIS ON YOUR C: OR YOUR WINDOWS HARDDRIVE!!!!!
Right click desktop and click [New->Shortcut]
Write: cmd.exe
Click [Next] then [Finish]
Right click the cmd.exe icon and click 'Run As Adminstrator"
Now select the external hard drive (F: in my case)
C:>f:
Now do the following (you can copy paste):
F:>attrib -s -h /S /D
F:>attrib -r /S /D
F:>rd "System Volume Information" /S
System Volume Information, Are you sure (Y/N)? y
And you're DONE ;-)
53 additional answers
    2012-04-19T00:20:50+00:00
    Thanks for that Ronnie Vernon, just got rid of my old system restore points, which took ~20GB of disk space and which weren't actually even being recognized by the system, i.e. if I would open System Restore it'd tell me there are no restore points! :]
    2012-12-07T02:47:49+00:00
    thanks...
    you resolved my problem it works... thanks...
    2013-01-14T15:08:11+00:00
    any ideas?
    thank you
    Good solution by MattiEinars (http://answers.microsoft.com/en-us/profile/78e77349-6ef7-4ee6-94b9-b485a6232e36) that I have also tried but in following easy way
    WinKey+R
    in Run dialog type "cmd /administrator" (don't use commas)
    now follow same procedure giveng by MattiEinars
    F:>attrib -r /S /D
    And you're DONE ;-)
    Don't worry if you don't need system restore you can remove SVI folder too
    2013-01-14T23:46:32+00:00
    Why try to delete the System Volume Information?  The simpler solution is to ensure that system restore does not monitor partitions other than the partition containing Windows, usually C. The System Volume Information folder contains files other than those used by system restore which occupy minimal disk space and which should not be deleted.
