Cannot delete system volume information folder on windows 7 !?!
2009-10-13T17:09:49+00:00
I cannot delete system volume information folder in D:/ E:/ on windows 7
I took ownership as admin on the folder but I cannot delete it completely!
I run an elevated command prompt and deleted some files in it but cannot remove the folder!
In vista I could mange to delete it after taking ownership on the folder by pressing del the folder will go away!
any ideas?
don`t ask me why I am trying to remove the folder pls...i just need to
thank you
2010-12-12T23:38:51+00:00
Old post I know but I've had this problem on several of my removeable HDs and finally I managed to remove the 'System Volume Information' folder:
DO NOT DO THIS ON YOUR C: OR YOUR WINDOWS HARDDRIVE!!!!!
Right click desktop and click [New->Shortcut]
Write: cmd.exe
Click [Next] then [Finish]
Right click the cmd.exe icon and click 'Run As Adminstrator"
Now select the external hard drive (F: in my case)
C:>f:
Now do the following (you can copy paste):
F:>attrib -s -h /S /D
F:>attrib -r /S /D
F:>rd "System Volume Information" /S
System Volume Information, Are you sure (Y/N)? y
And you're DONE ;-)
53 additional answers
    2009-12-26T12:37:10+00:00
    how you come to success to delet SVI folder on system volume?
    please help me out
    i also want to delet the same folder
    2010-10-03T14:24:25+00:00
    Could someone explain to me how to do this from repairs command prompt? when i go to the drives that i want to remove SVI from it says the folder isn't there?
    2010-12-05T15:16:37+00:00
    You do understand what files are in there, right?
    Your system restore points (that can save you from many problems are stored in there.)
    It is easy enough to move them to another drive, and there is a much easier way to clean them up (cleanmgr.exe)
    Generally, not a good idea to delete system files with brute force.
    VP Tech Services
    Cleanmgr doesnt even get rid of the $Wastebasket let alone the SVI -  I too tried the f8 command prompt and it didnt work either -
    What creates a System Volume Information ?   I just added another disk to the same system and it doesnt have an SVI
    This is on a 2GB External Sata disk but USB connected and I move it around all the time not that I should need a reason to as stated above by Windows7userdon`t ask me why I am trying to remove the folder pls...i just need toThe simple existence of it taking space is why I want it gone.
    Really appreciate aany help that knows how to delete and how it gets there in the first place......
    Happy Holidays,  Best Regards
    2010-12-21T16:28:38+00:00
    Write: cmd.exe
    C:>f:
    F:>attrib -r /S /D
    And you're DONE ;-)
    nothing happened as i typed commands and system volume infomation folder content undeleted ... any help pls ?
