Cannot delete system volume information folder on windows 7 !?!
2009-10-13T17:09:49+00:00
I cannot delete system volume information folder in D:/ E:/ on windows 7
I took ownership as admin on the folder but I cannot delete it completely!
I run an elevated command prompt and deleted some files in it but cannot remove the folder!
In vista I could mange to delete it after taking ownership on the folder by pressing del the folder will go away!
any ideas?
don`t ask me why I am trying to remove the folder pls...i just need to
thank you
2010-12-12T23:38:51+00:00
Old post I know but I've had this problem on several of my removeable HDs and finally I managed to remove the 'System Volume Information' folder:
DO NOT DO THIS ON YOUR C: OR YOUR WINDOWS HARDDRIVE!!!!!
Right click desktop and click [New->Shortcut]
Write: cmd.exe
Click [Next] then [Finish]
Right click the cmd.exe icon and click 'Run As Adminstrator"
Now select the external hard drive (F: in my case)
C:>f:
Now do the following (you can copy paste):
F:>attrib -s -h /S /D
F:>attrib -r /S /D
F:>rd "System Volume Information" /S
System Volume Information, Are you sure (Y/N)? y
And you're DONE ;-)
53 additional answers
    2013-04-29T13:23:17+00:00
    Write: cmd.exe
    C:>f:
    F:>attrib -r /S /D
    And you're DONE ;-)
    nothing happened as i typed commands and system volume infomation folder content undeleted ... any help pls ?
    If there are files within the SVI folder that are in use (there are system hidden files inside), the folder cannot be deleted, hence the -h -s flags.
    Make sure you select the correct drive. The example given was for Drive "F:"
    The SVI will be re-created by windows too
    You can remove All but the most recent restore points and deleting the SVI folder isn't recommended.
    2013-06-19T16:49:47+00:00
    I also have this kind of problem. I follow the instructions but in this part, " System Volume Information, Are you sure (Y/N)? y " , access is denied . . . how can i fix this? pls help.
    2013-09-11T08:08:55+00:00
    Excellent advice !
    Worked perfectly !  Just make sure you select the CORRECT drive and NOT YOUR C DRIVE !
    2013-11-09T15:49:09+00:00
    I tried that but it is showing Access Denied. Advise me.
