Customized Power Options keeps changing back to default
2009-12-11T04:55:38+00:00
Hi all,
I am running Windows Vista currently.
Have been trying to customised my own Power Options...
I changed the parameters & saved under another name.
Somehow after a few days or after reboot... when I turn on my laptop, it will turn back to the default settings & my customised plan is NOT there anymore! Only the 3 default ones (Balanced, Power Saver, High performance) is present.
It has been a frustating 2mths... doing it all over again & again...
Cant seem to find any solutions... pls help! =P
Regards,
Soya Ng
2009-12-12T03:58:57+00:00
Hi SoyaNg
Thank you for using Microsoft Answers Forums!
You can follow these steps to Customize your Power Options.
How to create a power plan
To create a power plan, follow these steps:
  1. Click Start, type Power Options in the Start Search box, and then click Power Options in the Programs list.
  2. On the Select a power plan page, click Create a power plan in the task pane. If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
  3. On the Create a power plan page, select the plan that is closest to the type of plan that you want to create. For example, if you want the plan to conserve energy, select the Power saver plan.
  4. In the Plan name box, type a name for the plan, and then click Next.
  5. In Change settings, select the display settings and the sleep settings that you want the computer to use when it is running on battery power and when it is plugged in, and then click Create.
If you are using a mobile PC, your plan appears under Plans on the battery meter. If you are using a desktop computer, your plan appears under Preferred plans.
Note The plan that you created automatically becomes the active plan. To put a different plan into effect, select that plan on the Power Options page.
How to customize a power plan
To customize a power plan, follow these steps:
  2. Click Change plan settings under the plan.
  3. On the Change settings for the plan page, select the display settings and the sleep settings that you want your computer to use, or click Change advanced power settings to change additional settings.
  4. Click OK, or click Save changes to save the changes.
Make sure that the power plan that you want the computer to use is selected on the Power Options page.
How to use the Powercfg.exe tool to set the active power plan
You can use the Powercfg.exe tool to control power settings and to configure computers to use the hibernate feature or the sleep feature. The Powercfg.exe tool is installed with Windows Vista and with Windows 7.
To set the active power plan by using the Powercfg.exe tool, follow these steps:
  1. Click Start, click All Programs, and then click Accessories.
  2. Right-click Command Prompt, and then click Run as Administrator. If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
  3. Type the following command, and then press ENTER:
Powercfg -setactiveScheme_GUID
NoteScheme_GUID represents the scheme GUID. To determine the GUID for all existing power schemes, type Powercfg /List at the command prompt, and then press ENTER.
How to use the registry to set the preferred power plan
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756  (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
To change the preferred power plan, follow these steps:
  1. Click Start, type regedit in the Start Search box, and then click regedit.exe in the Programs list. If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
  2. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\explorer\ControlPanel\NameSpace{025A5937-A6BE-4686-A844-36FE4BEC8B6D}
  1. Right-click PreferredPlan, and then click Modify.
  2. In the Value data box, enter one of the following:
    • Type 381b4222-f694-41f0-9685-ff5bb260df2e to use the Balanced plan.
    • Type a1841308-3541-4fab-bc81-f71556f20b4a to use the Power saver plan.
    • Type 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c to use the High performance plan.
You can also type the power scheme GUID for a custom power plan that you have created. To determine the GUID for all existing power schemes, type Powercfg /List at the command prompt, and then press ENTER.
  1. Click OK, and then exit Registry Editor.
You can refer to this link: http://support.microsoft.com/kb/935799
Hope this information was helpful.
Let me know if this worked.
All the best!
Thanks and Regards,
Uma R
  • Microsoft Support.
47 additional answers
    2014-12-24T21:10:34+00:00
    This is really frustrating.  The issue also exists on Microsoft's own Surface Pro 3.  I can't believe that it has been a known issue for so long and not addressed.  Though lately, I seem to be troubleshooting Windows more than using it!
    2014-12-24T22:22:40+00:00
    To:  Zaki J or Uma R (MS Support Engineer)
    I am using Win 7 Pro, on a desktop and I WANT my computer running all the time as it always used to.
    It has been a frustrating 2mths... doing it all over again & again...
    With all due respect , SoyaNG's is getting the same error described many, many times by me and others in this forum.  And as you know 25 reports in a forum most likely equals hundreds or even thousand of unreported issues.  I am personally offended that you are regurgitating manual instructions and then directing "amateurs" like myself to start messing around with their registry settings.
    Making changes is actually pretty straightforward in the Power Setting sections.  What's conspicuously absent is anything like a "SAVE" function for when you are done.  And that's EXACTLY what the problem is; the changes stay in effect for a day or two or three and then "randomly"  REVERT BACK on their own and without notice to exactly what they were.  Under some set of common circumstances, the system just fails to honor the customer's setting.  HELP US!
    Is it conceivable that MS can just admit that this feature is BROKEN?  Something in Windows is allowing these setting to change (reset themselves).  DOZENS of other windows settings stay set for YEARS at a time.  Surely an actual developer can track this down.  The functionality appears to be there--MS just needs to correct the ability to SAVE and then LOCK the changes!
    Why are you directing people to the registry for something a SIMPLE as (in my case) telling the system NOT to go to sleep???  MS "offers" the needed functionality.  Instead handing out programming "projects" to me, how about just fixing it so it works like it clearly was intended to?
    Thanking you again for looking in to this and hopefully fixing the bug.
    2015-02-14T16:39:18+00:00
    I read and followed this advice.  It fails to work.
    I’ve read all the following replies and when this respondent (doubt Zaki J is a real person) replied with the same cookie cutter blanket answer, it is clear either, if he’s real, that he’s an idiot or it’s a robo reply based on key words.
    Secondly since MS has failed to fix or even address the problem, I have to assume it’s the MS culture of they believe they know what is best for their users and force their will on us.  For example, this topic of Power Options, we all know that Bill G. is a flaming liberal and liberals are notorious for forcing conservative policies.  Usually it happens in Washington.  Here Billy is doing it through HIS software.  That is why you cannot change your power settings to an ‘always on’ state.  If you could, then it proves that no one at MS even reads these forums.
    2015-02-15T20:31:49+00:00
    The really simple question IS why won't MS address this?  Its OBVIOUSLY a problem.  The complicated and unnecessary nonsense being "auto-spewed" out by MS DOES NOT WORK, and much more importantly, its NOT our job to repair Microsoft's broken code.
    If its broken AND WE ALL KNOW IT IS, just treat your customers with some respect and CORRECT IT!.
    I'm not one for conspiracy theories, but it has crossed my mind as well that perhaps the MS Engineers in Redmond may choose no t to fix (or prioritize) this issue as it has an "environmental" component that doesn't quite suit their personal world view of how the rest of us "should" be running our businesses and lives.
    Microsoft, please just FIX IT!
