No low battery notification and my computer always just shuts off, I have all the right settings on
2010-05-19T07:07:41+00:00
I purchased my laptop now for about 6 months and the most annoying part is that there is never a low battery notification before my laptop hibernates. It has never shown up once.
The battery meter is active and shown in my system tray. I have gone into power options, changed advanced battery options for low, critical, and reserve levels as well as turned ON low battery notification. In system tray properties > notification area > customize > I have also selected "show icon and notifications".
The windows 7 microsoft website as well as many other forums only suggest to do these 2 things. I HAVE done these two things, as they were the original settings when I bought this laptop new...what else can I do? Is there a patch, download, anything?! I would rather not have to install 3rd party software. I would just like my laptop to function properly. I am not a heavy gamer or student, I just use my laptop to surf the web and watch videos. I also use free Avira antivirus, if any of this is important to why a battery notification won't show up.
Edit: My friend and I bought the exact same computer on the same day. His shows notifications and mine doesn't, so I know it's possible.
2014-11-25T13:08:22+00:00
Just open your
"control panel"
and then "power option" then
"change advance power settings"
there select  the profile you want to active( power saver ,high performance etc.)
Then scroll down to "battery" expand it and find "low battery notification" and turn  "on" for both "on battery" and "plugged in"  and you will done.
Note :- not necessary to turn it on for "plugged in"
81 additional answers
    2016-09-20T00:34:53+00:00
    I tried that and it didn't work, but thanks anyway.
    2016-09-23T17:47:33+00:00
    Hy gyz I hve acer laptop 2 months old but battery prblm is same it goes to hibernate suddenly and when try to on it show critical low battery.What to do i have done all low battery notification on but no pop ups comes it of sudden.
    2016-09-23T18:07:09+00:00
    I don't know how to fix it either and no one on this board can help. However, it isn't the type of laptop you have, it has something to do with windows 10. Mine used to be fine and then after one of the updates it became like that. All the settings are right, according to all this advice. But it doesn't make any difference. It's a Windows 10 thing. With all their updating, they should fix that!
    2016-09-23T21:56:14+00:00
    It's not just Windows 10, I have 8.1.
