No low battery notification and my computer always just shuts off, I have all the right settings on
2010-05-19T07:07:41+00:00
I purchased my laptop now for about 6 months and the most annoying part is that there is never a low battery notification before my laptop hibernates. It has never shown up once.
The battery meter is active and shown in my system tray. I have gone into power options, changed advanced battery options for low, critical, and reserve levels as well as turned ON low battery notification. In system tray properties > notification area > customize > I have also selected "show icon and notifications".
The windows 7 microsoft website as well as many other forums only suggest to do these 2 things. I HAVE done these two things, as they were the original settings when I bought this laptop new...what else can I do? Is there a patch, download, anything?! I would rather not have to install 3rd party software. I would just like my laptop to function properly. I am not a heavy gamer or student, I just use my laptop to surf the web and watch videos. I also use free Avira antivirus, if any of this is important to why a battery notification won't show up.
Edit: My friend and I bought the exact same computer on the same day. His shows notifications and mine doesn't, so I know it's possible.
2014-11-25T13:08:22+00:00
Just open your
"control panel"
and then "power option" then
"change advance power settings"
there select  the profile you want to active( power saver ,high performance etc.)
Then scroll down to "battery" expand it and find "low battery notification" and turn  "on" for both "on battery" and "plugged in"  and you will done.
Note :- not necessary to turn it on for "plugged in"
81 additional answers
    2016-08-04T19:57:43+00:00
    You can also try changing your Critical Battery Action to Shutdown from Hibernate for the Low Battery popped up and switch to a power source. Then, change the Critical Battery Action back to  Hibernate. If the Low Battery Notification will pop up then its good to go. If not,  We suggest to follow these steps:
    1. Right-click on an empty area on the task bar, then click Properties.
    2. Under Notification, click Customize.
    3. In Notification Area icon, you can click on Turn system icons on or off.
    4. And in  the Turn System icons page, under Behaviors, there will be a drop-down list, choose On and then click Ok.
    Let us know if you need further assistance.
    Regards,
    Kem Mon
    2016-08-16T10:52:20+00:00
    Thank you for your attempt, but I fear it is not a matter of notifications, rather some hardware issue, since it affects laptops belonging to certain model families (among HP and Asus). I have heard about energy management driver issue and also about solutions implying reflashing the BIOS. Is there anyone who has attempted these procedures?
    2016-08-24T07:32:04+00:00
    i have the battery notification option on but it still doesn't notify me
    2016-08-24T14:46:26+00:00
    Hi there,
    Thank you for reaching out, we're here to help. Please answer the following question below:
    1. What model of device are you using?
    2. Which version of Windows installed in your device?
    3. What troubleshooting have you done so far?
    We value all the information that you will provide to us. Hope to hear from you soon.
    Regards.
