Wireless Network Connection icon no longer on System Tray
2008-12-31T15:07:23+00:00
I used to have an icon in the notification area that showed the signal strength of the wireless network and would bring up the Connect To window when clicked. That icon has disappeared and I have not been able to figure out how to get it back.
I have not changed anything recently on the machine, at least not intentionally. So I have no idea what might have caused it to disappear. When I look at the system tray properties under  Notification Area/Customize the "Wireless Network Connection" icon appears in the Past Items area. Changing it to "show" did not make it reappear.
Thanks for the help.
2009-01-02T18:00:34+00:00
Hi Rob,
Make sure your drivers and devices associated with the system tray icons are installed and working properly as the icons will not work if the driver or device does not.
Let’s first try to uninstall and reinstall your device drivers to see if that resolves your issue.
  1. Open the Start Menu
  2. Type Device Manager in the Start Search area and press Enter
  3. Click on Continue in the UAC prompt
  4. Locate the Network adapters and press + next to it to expand the list
  5. Right-click the specific device you want, and then click Uninstall
  6. In the ConfirmDevice Removal page, select Delete the driver software for this device if you also want to remove the device driver package from the driver store
  7. Click OK to complete the uninstall process
  8. Repeat these steps for the sound device
  9. Close Device Manager and restart your computer
  10. Once you are logged in, reinstall the most up to date drivers for your devices.
  11. Once complete, see if the checkboxes are still grayed out or if the system try icons show up
If your issue is still not resolved then let’s continue with the steps below in order to try and fix this problem.
In order for the network icon to work properly, let us check to see if your network services are running correctly.
2.    Type services in the Start Search area and press Enter
4.    Locate Network Connections, Network List Service, Network Location Awareness, and Network Store Interface Service
5.    Verify that Status is set to Started and Startup Type is set to Automatic
6.    If this is not the case then right click the service and select Start to start the service
7.    Right click the service and select Properties and change the Startup type to Automatic
8.    Repeat as necessary for the services listed in step 4
Now that the services are running, we can enable the system tray icons by going into the registry.
Note: Modifying REGISTRY settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of REGISTRY settings can be solved. Modifications of these settings are at your own risk.
2.    Type regedit in the Start Search area and press Enter
4.    Navigate to:  HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
5.    To Enable the Volume Icon - Right click on HideSCAVolume and click on Delete
6.    To Enable the Network Icon - Right click on HideSCANetwork and click on Delete
7.    To Enable the Power (battery) Icon - Right click on HideSCABattery and click on Delete
8.    Close regedit and restart your computer to apply the changes
Please let me know if this helps or if you have any questions.
Matt
2008-12-31T18:57:44+00:00
Hi Rob-
I recently had this problem with a new laptop. I hope these steps will help you:
  1. Right click the Windows button (Start Menu), and select Properties.
  2. In the Properties dialog box, click the Notification Area tab.
  3. In the Systems Icons area, ensure that the Network checkbox is selected.
  4. Click Apply, then Ok.
Please let me know if this helps!
Barb Winter
Microsoft Answers Program Manager
55 additional answers
    2010-02-07T08:13:06+00:00
    1st Please Reboot so nothing is interferring with this process.
    These tell you how to enable them even when grayed out and/or will do it for you.
    How to Enable or Disable the Notification Area System Icons in Vista
    http://www.vistax64.com/tutorials/106787-notification-area-system-icons.html
    If needed : a Mr Fixit
    System icons do not appear in the notification area in Windows Vista or in Windows 7 until you
    restart the computer
    http://support.microsoft.com/default.aspx/kb/945011
    Hope this helps.
    Rob - Bicycle - Mark Twain said it right.
    2010-02-11T21:54:18+00:00
    Hope this helps.
    Neither this nor the other registry fixes in this thread worked for me. Volume, Network, and Action Center icons are OFF and the drop-down menu is greyed out. How do I reinstall drivers for the Action Center?
    2010-02-11T22:31:50+00:00
    Do these to clear corruption and repair/replace damaged/missing system files.
    Start - type in Search box -  COMMAND   find at top of list -  RIGHT CLICK  -  RUN AS ADMIN
    sfc /scannow
    How to analyze the log file entries that the Microsoft Windows Resource Checker (SFC.exe) program
    generates in Windows Vista cbs.log
    http://support.microsoft.com/kb/928228
    Then run checkdisk - schedule it to run at next start and then Apply OK your way out then restart.
    How to Run Check Disk at Startup in Vista
    http://www.vistax64.com/tutorials/67612-check-disk-chkdsk.html
    Are you using Ultimate or Business where Group Policies (GPEdit) come into play?
    Some antivirus/security products could be causing this error. McAfee, Norton, Windows Live OneCare,
    Threatfire are a few. Which antivirus/antispyware/security products do you have on machine now. And
    which have you EVER had on it even if you uninstalled them. (These leave remnants which cause
    strange issues.)
    Check the default services and dependencies to make sure they are running.
    http://www.blackviper.com/WinVista/Services/Security\_Center.htm
    Security Center Not Reporting Anti-Virus or Firewall Status Correctlyhttp://www.pchell.com/support/multiple_antivirus_in_security_center.shtmlhttp://www.winhelponline.com/blog/security-center-not-reporting-anti-virus-or-firewall-status-correctly/
    How to Fix the Vista Security Center Reporting Incorrect Information
    http://www.vistax64.com/tutorials/195736-security-center-not-reporting-correct-information.html
    How to Disable or Enable Security Center in Vista
    http://www.vistax64.com/tutorials/67737-security-center.html
    This thread might help as it might be a permissions issue.
    http://social.answers.microsoft.com/Forums/en-US/vistawu/thread/3d2049ae-4581-439b-8e15-3f603f5c60f0/
    Hope this helps.
