Wireless Network Connection icon no longer on System Tray
2008-12-31T15:07:23+00:00
I used to have an icon in the notification area that showed the signal strength of the wireless network and would bring up the Connect To window when clicked. That icon has disappeared and I have not been able to figure out how to get it back.
I have not changed anything recently on the machine, at least not intentionally. So I have no idea what might have caused it to disappear. When I look at the system tray properties under  Notification Area/Customize the "Wireless Network Connection" icon appears in the Past Items area. Changing it to "show" did not make it reappear.
Thanks for the help.
2009-01-02T18:00:34+00:00
Hi Rob,
Make sure your drivers and devices associated with the system tray icons are installed and working properly as the icons will not work if the driver or device does not.
Let’s first try to uninstall and reinstall your device drivers to see if that resolves your issue.
  1. Open the Start Menu
  2. Type Device Manager in the Start Search area and press Enter
  3. Click on Continue in the UAC prompt
  4. Locate the Network adapters and press + next to it to expand the list
  5. Right-click the specific device you want, and then click Uninstall
  6. In the ConfirmDevice Removal page, select Delete the driver software for this device if you also want to remove the device driver package from the driver store
  7. Click OK to complete the uninstall process
  8. Repeat these steps for the sound device
  9. Close Device Manager and restart your computer
  10. Once you are logged in, reinstall the most up to date drivers for your devices.
  11. Once complete, see if the checkboxes are still grayed out or if the system try icons show up
If your issue is still not resolved then let’s continue with the steps below in order to try and fix this problem.
In order for the network icon to work properly, let us check to see if your network services are running correctly.
2.    Type services in the Start Search area and press Enter
4.    Locate Network Connections, Network List Service, Network Location Awareness, and Network Store Interface Service
5.    Verify that Status is set to Started and Startup Type is set to Automatic
6.    If this is not the case then right click the service and select Start to start the service
7.    Right click the service and select Properties and change the Startup type to Automatic
8.    Repeat as necessary for the services listed in step 4
Now that the services are running, we can enable the system tray icons by going into the registry.
Note: Modifying REGISTRY settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of REGISTRY settings can be solved. Modifications of these settings are at your own risk.
2.    Type regedit in the Start Search area and press Enter
4.    Navigate to:  HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
5.    To Enable the Volume Icon - Right click on HideSCAVolume and click on Delete
6.    To Enable the Network Icon - Right click on HideSCANetwork and click on Delete
7.    To Enable the Power (battery) Icon - Right click on HideSCABattery and click on Delete
8.    Close regedit and restart your computer to apply the changes
Please let me know if this helps or if you have any questions.
Matt
2008-12-31T18:57:44+00:00
Hi Rob-
I recently had this problem with a new laptop. I hope these steps will help you:
  1. Right click the Windows button (Start Menu), and select Properties.
  2. In the Properties dialog box, click the Notification Area tab.
  3. In the Systems Icons area, ensure that the Network checkbox is selected.
  4. Click Apply, then Ok.
Please let me know if this helps!
Barb Winter
Microsoft Answers Program Manager
55 additional answers
    2010-03-12T05:02:46+00:00
    Hi Milam C.,
    Did you try the fix method from my message on Sunday, February 07, 2010 8:13 AM?
    Rob - Bicycle - Mark Twain said it right.
    2010-06-12T04:40:02+00:00
    Microsoft is weird, I got this problem resolved in weird way. For me, Network and Volume were disabled and greyed out under Notification Area settings tab. Interestingly this was fine in another profile under the same computer. So, I was convinced that it is not an issue with drivers, its probably some bug in Windows Vista.
    Then just for trying out, I tried starting in safe mode. Now, I could see Power disabled and greyed out, but Network and Volume checked as well as not greyed out.
    Then I unchecked Network, Volume, checked them again and clicked Apply.
    Restarted computer, now I could see Network and Volume still unchecked, but fortunately not greyed out.
    I checked them again, and living happily thereafter.
    As I said, MS products can have these strage bugs, and sometimes they get resolved in extremely strange manner. Hope such troubleshooting helps you too.
    Note: I hope MS Support Engineers ask more details to understand problem better instead of straightaway suggesting driver uninstalling/installing etc. For ex: in this case, if such issue exists for different login, or in safe mode - thats a pretty basic thing to check and looking at above posts, I dont see they did check such stuff from issue reporter.
    Regards,
    Krishna.
    2010-07-19T13:26:03+00:00
    Here's a solution:
    Step 1: CTRL + SHIFT + ESC (brings up the task manager)
    Step 2: On processes tab find "Explorer.exe"
    Step 3: Click End Process
    Step 4: Click File--> New Task
    Step 5: Type Explorer.exe by restarting this executable corrects the settings
