“Display driver stopped responding and has recovered” error.
2009-10-13T16:38:34+00:00
  • Running Windows 7, 32-bi,t on a Lenovo W500. Display Driver: ATI Mobility Radeon HD 3650.
  • The error message (“display driver stopped responding & has recovered”) follows a system freeze, a short blackout. Then everything works fine.
  • Downloaded the most current driver from the company's Web site.
  • Seeemd to work for a day, but now I'm getting the same behavior.
Crabby Office Lady
2012-01-27T00:10:30+00:00
Hello Crabby Office Lady,
This error can happen because of an outdated video driver, to many programs running at one time or even high CPU activity. There is a link to a KB article on the following post that gives more info on the issue and helps to fix it, see:
http://answers.microsoft.com/en-us/windows/forum/windows_7-performance/error-display-driver-stopped-responding-and-has/1b6c2b8b-b0a7-49d9-bc3b-e9cc98d51004
L.D.
334 additional answers
    2011-11-11T03:40:01+00:00
    2011-11-12T06:29:20+00:00
    After many weeks of Googling, going through 100 threads, trying many of the solutions (some of which being ridiculous like reformatting, replacing hardware, etc.), I found ONE POST that suggested what I can now confirm fixes this problem. Not "it hasn't happened yet, keeping my fingers crossed", but actually fixed.
    THE SOLUTION:
    Nvidia Control Panel -> 3D Settings -> Set PhysX configuration -> Select a Physx processor -> choose your graphics card instead of leaving it on auto-select.
    I'm telling you guys, try this.
    2011-11-20T02:13:56+00:00
    Hi guys,
    try this one:
    • open regedit.exe
    • navigate to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\GraphicsDrivers
    • right click (on empty space) to create new entry > DWORD (32 bit) Value
    • name it to TdrLevel
    • double click on it and set value data to 0   (zero)
    It seems it works.
    Microsoft's information about this registry key:
    • TdrLevel Specifies the initial level of recovery. The default value is to recover on timeout (TdrLevelRecover).
    KeyPath : HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\GraphicsDrivers KeyValue : TdrLevel ValueType : REG_DWORD ValueData : TdrLevelOff (0) - Detection disabled TdrLevelBugcheck (1) - Bug check on detected timeout, for example, no recovery. TdrLevelRecoverVGA (2) - Recover to VGA (not implemented). TdrLevelRecover (3) - Recover on timeout. This is the default value.
    2011-11-20T02:26:40+00:00
    Immediate correction:
    Sorry, it is NOT a solution. The problem is still appearing. :-(
