“Display driver stopped responding and has recovered” error.
2009-10-13T16:38:34+00:00
  • Running Windows 7, 32-bi,t on a Lenovo W500. Display Driver: ATI Mobility Radeon HD 3650.
  • The error message (“display driver stopped responding & has recovered”) follows a system freeze, a short blackout. Then everything works fine.
  • Downloaded the most current driver from the company's Web site.
  • Seeemd to work for a day, but now I'm getting the same behavior.
Crabby Office Lady
2012-01-27T00:10:30+00:00
Hello Crabby Office Lady,
This error can happen because of an outdated video driver, to many programs running at one time or even high CPU activity. There is a link to a KB article on the following post that gives more info on the issue and helps to fix it, see:
http://answers.microsoft.com/en-us/windows/forum/windows_7-performance/error-display-driver-stopped-responding-and-has/1b6c2b8b-b0a7-49d9-bc3b-e9cc98d51004
L.D.
334 additional answers
    2011-10-23T17:12:04+00:00
    I Had the same problem and I FIXED it, the problem was because of a Damaged RAM's one of your ram's is damaged, try to take them out one by one and fix it, in my case i had 4x2GB and I had to remove 2 and it worked. The system is Stable and I'm playing WoW Cata and the Error didn't come back.
    P.S. I Replaced the PCI-E VGA from 9400 GT to GTX 550Ti (the problem persisted on both) till I changed RAM.
    Intel Quad 2.4Ghz
    Gigabyte P43-ES3G
    4 GB of RAM Kingston
    Nvidia GTX 550 Ti
    Windows 7 Ultimate
    Thermaltake Speedo Case
    2011-10-24T18:53:05+00:00
    i have nvidia gtx460 and have this problem, at one time, i took out one of my ram cards nd couldn't get it in again, eventually i did though, this might be my problem too, i recently ordered 8gb of ram so i'll install that and remove the other 2 and i'll reply if it works :)
    2011-10-25T15:02:29+00:00
    i have problems of display driver stopped working...."
    Dell inspiron windows vista 32 bit.
    Appreciate your help.
    2011-10-25T23:17:43+00:00
    i downgraded to the 275.33 and so far i've had abdoloutly no problems touch wood, heres the link to the download - http://www.nvidia.co.uk/content/DriverDownload-March2009/confirmation.php?url=/Windows/275.33/275.33-desktop-win7-winvista-32bit-international-whql.exe&lang=uk&type=GeForce
    hope it helps you like it did for me :) good luck
