“Display driver stopped responding and has recovered” error.
2009-10-13T16:38:34+00:00
  • Running Windows 7, 32-bi,t on a Lenovo W500. Display Driver: ATI Mobility Radeon HD 3650.
  • The error message (“display driver stopped responding & has recovered”) follows a system freeze, a short blackout. Then everything works fine.
  • Downloaded the most current driver from the company's Web site.
  • Seeemd to work for a day, but now I'm getting the same behavior.
Crabby Office Lady
2012-01-27T00:10:30+00:00
Hello Crabby Office Lady,
This error can happen because of an outdated video driver, to many programs running at one time or even high CPU activity. There is a link to a KB article on the following post that gives more info on the issue and helps to fix it, see:
http://answers.microsoft.com/en-us/windows/forum/windows_7-performance/error-display-driver-stopped-responding-and-has/1b6c2b8b-b0a7-49d9-bc3b-e9cc98d51004
L.D.
334 additional answers
    2011-09-16T16:15:00+00:00
    I installed all updates for my graphics card I did a scan for what drivers were missing and since updating my graphics card its showing display driver fault.....
    2011-09-17T15:39:31+00:00
    Hi.
    This happens to me too, on my new Fujitsu Amilo - Win 7 - 32 bit (made in Germany please..lol).
    It happens when I scroll down an Internet page, or have several internet pages open. I found on the net that it would happen less, if your Temporary Internet Files is empty (i.e. not cookies etc.)
    I tried it and it does not happen when it's empty.
    But reading all the issues here since 2009, I do think that Windows is the culprit.
    Try the old good defragmenting, cleanup or even restore. And use a software to check your registry.
    As I said, I don't get this problem so often (thank God), but performing the classic system maintenance can help.
    So to resume... empty the Tempory Internet Files, fix Registry errors, perform cleanup and defragment, or try a System Restore (it's always my last weapon).
    This problem has got nothing to do with heat.
    If someone has other easy solutions, please let me know.
    2011-09-17T23:11:27+00:00
    I have a Fujitsu T4220 which had the display driver problems mentioned here.  They seemed to have occured when I pressed the enter key like it was an execution problem.
    When I booted in Safe Mode the problems disappeared.
    Then I read  "Chen YF" suggestion  & changed the display color as "High Color (16 bit)" instead of "True Color (32 bit)"  and the problem went away.
    Can someone tell me in layman terms why this fixed the problem.
    David
    2011-09-18T11:06:30+00:00
    Better not to change reg values.
    Common values are between 2 and 5 seconds.
    Please note that 2 seconds is actually a high value.
