Disk Management Console view is not up-to-date.
2009-10-24T18:44:59+00:00
OS Name Microsoft® Windows Vista™ Ultimate
Version 6.0.6002 Service Pack 2 Build 6002
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name -----
System Manufacturer INTEL_
System Model DP45SG
System Type X86-based PC
Processor Intel(R) Core(TM)2 Quad CPU    Q6700  @ 2.66GHz, 2660 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date Intel Corp. SGP4510H.86A.0083.2008.0819.1026, 8/19/2008
SMBIOS Version 2.4
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.0.6002.18005"
User Name -----
Time Zone Eastern Daylight Time
Installed Physical Memory (RAM) 2.00 GB
Total Physical Memory 2.00 GB
Available Physical Memory 691 MB
Total Virtual Memory 4.23 GB
Available Virtual Memory 2.38 GB
Page File Space 2.29 GB
Page File C:\pagefile.sys
Partition **** Disk #0, Partition #0
Partition Size **** 104.43 GB (112,134,193,664 bytes)
Partition Starting Offset 1,048,576 bytes
Partition **** Disk #0, Partition #1
Partition Size **** 361.33 GB (387,979,805,696 bytes)
Partition Starting Offset 112,133,668,864 bytes
I went to do something with partition magic (it recognized something with the pointers I believe, so I allowed it to automatically fix the error) and now I'm not even able to access Partition Disk #0, Partition #1 which is a drive that I used to store data (No OS).  It doesn't appear in 'My Computer', but does appear in Disk Management but it doesn't seem like I can do anything with it besides delete the partition.  There's a lot of data that I have stored and I don't want to lose it all.
I used a partition tool to find out what sectors each of the partitions are starting at and for one of them it's sector 15 and the other it is sector 33.  I'm not sure if that has any significance to my problem, but just thought I'd let it be known.
  • Program: Disk Managemet
  • Error Message: "The operation failed to complete because the Disk Management console view is not up-to-date.  Refresh the view by using the refresh task.  If the problem persists close the Disk Management console, then restart Disk Management or restart the computer.
2010-01-25T12:43:17+00:00
I solved this problem by going into device manager and uninstalling the usb drivers. Then when I plugged the hard drive back in it reinstalled the driver and worked.
2009-11-07T15:01:11+00:00
Hello trichard13,
Thank you for visiting the Microsoft Answers Community.
Try using diskpart to assign a drive letter to Disk #0, Partition #1.
·          Click Start Orb > type diskpart
·          Right-click diskpart in results above > click Run as administrator
·          Once diskpart loads type list volume, press enter
You should notice that you will see your partition that you use for your data, it should not show a drive letter assigned to it.
·          Type select volume 6 **** (replace 6 with the volume number assigned to the partition in question)
·          Type assign letter Z (replace Z with the letter that you want to assign to it)
When you look in Computer, you should be able to see your partition.
Hope this helps
Chris.H
156 additional answers
    2013-08-11T18:08:49+00:00
    3 years on and Ahmad Ibrahim's comment is still helping people. worked perfect for me. thanks
    2013-08-13T04:35:17+00:00
    Sir,
    kindly help me, how to open  start Orb
    Regards,
    ANAND
    2013-08-13T05:07:54+00:00
    The Start Orb mentioned her is the Windows Vista and Windows 7 version of the Start Menu.
    You can open it by pressing the windows key or usually clicking something in the lower left corner.
    Pressing Windows + R and then typing diskpart should work as well.
