Disk Management Console view is not up-to-date.
2009-10-24T18:44:59+00:00
OS Name Microsoft® Windows Vista™ Ultimate
Version 6.0.6002 Service Pack 2 Build 6002
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name -----
System Manufacturer INTEL_
System Model DP45SG
System Type X86-based PC
Processor Intel(R) Core(TM)2 Quad CPU    Q6700  @ 2.66GHz, 2660 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date Intel Corp. SGP4510H.86A.0083.2008.0819.1026, 8/19/2008
SMBIOS Version 2.4
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.0.6002.18005"
User Name -----
Time Zone Eastern Daylight Time
Installed Physical Memory (RAM) 2.00 GB
Total Physical Memory 2.00 GB
Available Physical Memory 691 MB
Total Virtual Memory 4.23 GB
Available Virtual Memory 2.38 GB
Page File Space 2.29 GB
Page File C:\pagefile.sys
Partition **** Disk #0, Partition #0
Partition Size **** 104.43 GB (112,134,193,664 bytes)
Partition Starting Offset 1,048,576 bytes
Partition **** Disk #0, Partition #1
Partition Size **** 361.33 GB (387,979,805,696 bytes)
Partition Starting Offset 112,133,668,864 bytes
I went to do something with partition magic (it recognized something with the pointers I believe, so I allowed it to automatically fix the error) and now I'm not even able to access Partition Disk #0, Partition #1 which is a drive that I used to store data (No OS).  It doesn't appear in 'My Computer', but does appear in Disk Management but it doesn't seem like I can do anything with it besides delete the partition.  There's a lot of data that I have stored and I don't want to lose it all.
I used a partition tool to find out what sectors each of the partitions are starting at and for one of them it's sector 15 and the other it is sector 33.  I'm not sure if that has any significance to my problem, but just thought I'd let it be known.
  • Program: Disk Managemet
  • Error Message: "The operation failed to complete because the Disk Management console view is not up-to-date.  Refresh the view by using the refresh task.  If the problem persists close the Disk Management console, then restart Disk Management or restart the computer.
2010-01-25T12:43:17+00:00
I solved this problem by going into device manager and uninstalling the usb drivers. Then when I plugged the hard drive back in it reinstalled the driver and worked.
2009-11-07T15:01:11+00:00
Hello trichard13,
Thank you for visiting the Microsoft Answers Community.
Try using diskpart to assign a drive letter to Disk #0, Partition #1.
·          Click Start Orb > type diskpart
·          Right-click diskpart in results above > click Run as administrator
·          Once diskpart loads type list volume, press enter
You should notice that you will see your partition that you use for your data, it should not show a drive letter assigned to it.
·          Type select volume 6 **** (replace 6 with the volume number assigned to the partition in question)
·          Type assign letter Z (replace Z with the letter that you want to assign to it)
When you look in Computer, you should be able to see your partition.
Hope this helps
Chris.H
156 additional answers
    2013-07-24T07:09:25+00:00
    ... While messing with diskpart in an attempt to solve my problem I noticed AUTOMOUNT in the list of commands.  This command "enables and disables the automatic mounting of basic volumes."  On my system, automount was turned off.  After enabling it using the command, I found my remote hard drive in the device manager, and uninstalled the driver.  Unplugging and plugging the drive caused the computer to again install the driver, but this time it mounted it in My Computer as well.  Now my device was visible in said location, but for some reason my access was denied.  I resolved this by enabling sharing under the advanced sharing tab in the device properties.  Problem solved.  I can now use the drive and did not have to use disk management or format anything.
    Yay! This worked for me using Windows 7! Here is the step by step version:
    1. From RUN, type diskpart and click OK
    2. At the DISKPART prompt, type automount
    3. From the Device Manager , find the device not being recognized. Mine was under Storage Devices, I think.
    4. Right click on the device and choose Properties
    5. Click on the Driver tab
    6. Click Uninstall
    7. Unplug the device
    8. Plug the device back in
    The driver was automatically installed, it's mounted to My Computer and I immediately got the AutoPlay window.
    Thanks for that. I got my solution from here.
    In my case, the autodetect was enabled, but since i read a lot of forums to find answer to this question then i suspected the problem began after installing my phone program on the pc.
    Anyway this solved problem for me:
    start-run "diskpart" +ok
    automount disable
    Automount enable
    Deleted drive drivers
    unplugged, replugged and works like a charm :)
    2013-07-24T12:49:40+00:00
    ANSWERThis is how i fixed it, i dont know if it will work for you.
    Go to start and type "diskpart"
    run it as admin
    type list volume
    type select volume (number of usb) as an example 9
    type clean
    type format
    when the format window pops up, try doing that. if that works then no need to continue
    if it didnt, go to start
    right clikc computer
    go to manage
    go to disk utility
    right click the usb and it should let you assign a letter path now :)
    2013-08-02T15:16:55+00:00
    I solve this problem and save all data with a different way.
    First of all i would like tell you, " Partition Magic " is causing this kind of problems.It's asking to fix something and you click YES and then your problem is starting.One of ur partition is LOST :)
    As a solution;
    I use "TestDisk" get inside of Partition, copied all data to another partition and then go to Disk Management "Delete" partition and rebuild it.
    This is how i did save my data and solve the problem.
    Wish u luck.
