I solved this problem by going into device manager and uninstalling the usb drivers. Then when I plugged the hard drive back in it reinstalled the driver and worked.
Disk Management Console view is not up-to-date.
OS Name Microsoft® Windows Vista™ Ultimate
Version 6.0.6002 Service Pack 2 Build 6002
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name -----
System Manufacturer INTEL_
System Model DP45SG
System Type X86-based PC
Processor Intel(R) Core(TM)2 Quad CPU Q6700 @ 2.66GHz, 2660 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date Intel Corp. SGP4510H.86A.0083.2008.0819.1026, 8/19/2008
SMBIOS Version 2.4
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.0.6002.18005"
User Name -----
Time Zone Eastern Daylight Time
Installed Physical Memory (RAM) 2.00 GB
Total Physical Memory 2.00 GB
Available Physical Memory 691 MB
Total Virtual Memory 4.23 GB
Available Virtual Memory 2.38 GB
Page File Space 2.29 GB
Page File C:\pagefile.sys
Partition **** Disk #0, Partition #0
Partition Size **** 104.43 GB (112,134,193,664 bytes)
Partition Starting Offset 1,048,576 bytes
Partition **** Disk #0, Partition #1
Partition Size **** 361.33 GB (387,979,805,696 bytes)
Partition Starting Offset 112,133,668,864 bytes
I went to do something with partition magic (it recognized something with the pointers I believe, so I allowed it to automatically fix the error) and now I'm not even able to access Partition Disk #0, Partition #1 which is a drive that I used to store data (No OS). It doesn't appear in 'My Computer', but does appear in Disk Management but it doesn't seem like I can do anything with it besides delete the partition. There's a lot of data that I have stored and I don't want to lose it all.
I used a partition tool to find out what sectors each of the partitions are starting at and for one of them it's sector 15 and the other it is sector 33. I'm not sure if that has any significance to my problem, but just thought I'd let it be known.
- Program: Disk Managemet
- Error Message: "The operation failed to complete because the Disk Management console view is not up-to-date. Refresh the view by using the refresh task. If the problem persists close the Disk Management console, then restart Disk Management or restart the computer.
Hello trichard13,
Thank you for visiting the Microsoft Answers Community.
Try using diskpart to assign a drive letter to Disk #0, Partition #1.
· Click Start Orb > type diskpart
· Right-click diskpart in results above > click Run as administrator
· Once diskpart loads type list volume, press enter
You should notice that you will see your partition that you use for your data, it should not show a drive letter assigned to it.
· Type select volume 6 **** (replace 6 with the volume number assigned to the partition in question)
· Type assign letter Z (replace Z with the letter that you want to assign to it)
When you look in Computer, you should be able to see your partition.
Hope this helps
Chris.H
156 additional answers
2013-03-13T17:22:06+00:00 ... While messing with diskpart in an attempt to solve my problem I noticed AUTOMOUNT in the list of commands. This command "enables and disables the automatic mounting of basic volumes." On my system, automount was turned off. After enabling it using the command, I found my remote hard drive in the device manager, and uninstalled the driver. Unplugging and plugging the drive caused the computer to again install the driver, but this time it mounted it in My Computer as well. Now my device was visible in said location, but for some reason my access was denied. I resolved this by enabling sharing under the advanced sharing tab in the device properties. Problem solved. I can now use the drive and did not have to use disk management or format anything.
Yay! This worked for me using Windows 7! Here is the step by step version:
- From RUN, type diskpart and click OK
- At the DISKPART prompt, type automount
- From the Device Manager , find the device not being recognized. Mine was under Storage Devices, I think.
- Right click on the device and choose Properties
- Click on the Driver tab
- Click Uninstall
- Unplug the device
- Plug the device back in
The driver was automatically installed, it's mounted to My Computer and I immediately got the AutoPlay window.
Thank you very much
This has worked for me, simple but a perfect solution to the problem.
2013-03-30T13:52:00+00:00 On some un-initialized disks disk part and disk manager have a problem initializing a disks as MBR. I seem to remember WinNT 4.x initialially had a simular problem... Thanks for reminding me of the solution...
###NOTE### - Here is the error I had on Win7 with a new un-initialized disk...
Microsoft DiskPart version 6.1.7600
Copyright (C) 1999-2008 Microsoft Corporation.
On computer: ZEUS
DISKPART> select disk 1
DISKPART> list disk
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 596 GB 0 B *
Disk 1 Online 596 GB 596 GB
DISKPART> convert mbr
DISKPART> create partition primary SIZE=100 OFFSET=1
Virtual Disk Service error: The operation timed out. DiskPart has referenced an object which is not up-to-date. Refresh the object by using theRESCAN command. If the problem persists exit DiskPart, then restart DiskPart or restart the computer.
Here was the fix... This was done on a I can now also create partions with the Disk Management GUI.
DISKPART> list disk
DISKPART> clean
DiskPart succeeded in cleaning the disk.
DISKPART> convert gpt
DiskPart successfully converted the selected disk to GPT format.
DiskPart successfully converted the selected disk to MBR format.
DISKPART> create partition primary size=100 offset=1
DiskPart succeeded in creating the specified partition.
LIFE IS NOW GOOD! Thanks again...
i did this and now i lost the whole 2TB Hdd
anyone kind enough to guide me how to undo this?
Thanks a lot!
2013-04-19T18:48:21+00:00 Thank you! Had the exact same issue!
