I solved this problem by going into device manager and uninstalling the usb drivers. Then when I plugged the hard drive back in it reinstalled the driver and worked.
Disk Management Console view is not up-to-date.
OS Name Microsoft® Windows Vista™ Ultimate
Version 6.0.6002 Service Pack 2 Build 6002
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name -----
System Manufacturer INTEL_
System Model DP45SG
System Type X86-based PC
Processor Intel(R) Core(TM)2 Quad CPU Q6700 @ 2.66GHz, 2660 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date Intel Corp. SGP4510H.86A.0083.2008.0819.1026, 8/19/2008
SMBIOS Version 2.4
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.0.6002.18005"
User Name -----
Time Zone Eastern Daylight Time
Installed Physical Memory (RAM) 2.00 GB
Total Physical Memory 2.00 GB
Available Physical Memory 691 MB
Total Virtual Memory 4.23 GB
Available Virtual Memory 2.38 GB
Page File Space 2.29 GB
Page File C:\pagefile.sys
Partition **** Disk #0, Partition #0
Partition Size **** 104.43 GB (112,134,193,664 bytes)
Partition Starting Offset 1,048,576 bytes
Partition **** Disk #0, Partition #1
Partition Size **** 361.33 GB (387,979,805,696 bytes)
Partition Starting Offset 112,133,668,864 bytes
I went to do something with partition magic (it recognized something with the pointers I believe, so I allowed it to automatically fix the error) and now I'm not even able to access Partition Disk #0, Partition #1 which is a drive that I used to store data (No OS). It doesn't appear in 'My Computer', but does appear in Disk Management but it doesn't seem like I can do anything with it besides delete the partition. There's a lot of data that I have stored and I don't want to lose it all.
I used a partition tool to find out what sectors each of the partitions are starting at and for one of them it's sector 15 and the other it is sector 33. I'm not sure if that has any significance to my problem, but just thought I'd let it be known.
- Program: Disk Managemet
- Error Message: "The operation failed to complete because the Disk Management console view is not up-to-date. Refresh the view by using the refresh task. If the problem persists close the Disk Management console, then restart Disk Management or restart the computer.
Hello trichard13,
Thank you for visiting the Microsoft Answers Community.
Try using diskpart to assign a drive letter to Disk #0, Partition #1.
· Click Start Orb > type diskpart
· Right-click diskpart in results above > click Run as administrator
· Once diskpart loads type list volume, press enter
You should notice that you will see your partition that you use for your data, it should not show a drive letter assigned to it.
· Type select volume 6 **** (replace 6 with the volume number assigned to the partition in question)
· Type assign letter Z (replace Z with the letter that you want to assign to it)
When you look in Computer, you should be able to see your partition.
Hope this helps
Chris.H
156 additional answers
2012-04-05T11:03:51+00:00 I had the same problem
I get a tool called Acronis Disk Director Suite
setup the software then open it
right click on the partition without letter > Advanced > Convert
choose NTFS and if the partition is primary choose logical and vice versa
then apply changes
after that right click on the same partition > Change Letter
ALL YOUR DATA IS SAFE NO NEED TO PANIC
Thanks much!! This solution helped my life!!!
2012-04-14T17:47:46+00:00 OS Name Microsoft® Windows Vista™ Ultimate
System Name -----
System Model DP45SG
SMBIOS Version 2.4
User Name -----
I had the same problem - drives D & E dissapeared after I simply launched Partition Magic 8 on Windows 7 64bit. Upon start, Partition Magic happily announced me that it found some "problems" on these drives and fixed them for me (such a nice fellow, this Partition Magic!...) After rebooting, the drives were gone. The Windows Disk Management was seeing the drives, with no letters assigned, but wouldn't let me assign letters to them (the "Refresh..." error above)
HOW I FIXED IT:
- I downloaded and burned the MiniTool Partition Wizard Boot CD
- I booted into it, selected drive D and chose "Set as active"
After rebooting into Windows, both the D and the E drive were available again.
Hope this helps :)
2012-04-16T00:34:04+00:00 I had the same problem
then apply changes
Thank you very very much!! Love you Bro :)
This is the best and 110% accurate solution to solve this hectic problem. Just follow the instructions and you will get back your partition(s) with all the data safe and sound.
RuK' D
