Disable caps lock key
2010-02-01T16:30:30+00:00
I have done web searches on how to disable that pesky caps lock key, but I thought you guys might provide safer answers. I am reasonably proficient with computers, but my fat fingers keeps hitting the CAPS LOCK KEY AND THEN EVERYTHING LOOKS LIKE THIS UNTIL I REALIZE IT AND GO BACK AND re-type it. I do it a lot and it is driving me nuts! Help please!
Thanks so much!
2010-02-01T18:02:04+00:00
I understand that you found some suggestions about registry edition - they are not so bad. If you don't want to download any files which allow you to disable CAPS LOCK, you can create it by your own:
  1. Press WinKey+R > type notepad and press Enter
  2. Paste to the notepad this:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=hex:00,00,00,00,00,00,00,00,02,00,00,00,00,00,3a,00,00,00,00,00 3. File > Save As...
- Select for **Save as type: All Files**
- Enter in the **File name** field: **disable\_caps\_lock.reg**
- Click **Save**
  1. Right click on the created file > Merge
  2. Restart your system
In the case that you want to enable CAPS LOCK again, you need to delete that registry entry, so you need follow these steps:
  1. Press WinKey+R > type regedit and press Enter
  2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout
  3. Right click on the Scancode Map > Delete
  4. Restart your system
I guess it might be the only way to disable CAPS LOCK.
In the case that you still don't want to do that, Windows 7 is offering something different than disabling CAPS LOCK. You can enable Toggle Keys, so you are going to hear a tone when you press CAPS LOCK. To do this follow these steps:
  1. Press Start > Control Panel > Easy of Access   > Easy of Access Center > Make the keyboard easier to use
  2. Mark the Turn on Toggle Keys checkbox
65 additional answers
    2014-07-18T17:43:42+00:00
    This worked easily and perfectly for me.
    Downloading/installing took a few seconds.
    Thanks so much!
    2014-08-22T02:28:31+00:00
    Thanks a lot.  You saved my day :)
    2014-11-07T23:01:48+00:00
    This does not work for Windows 8.1+. I've tried it repeatedly. Any suggestions for users of the new version? Thanks.
    2016-01-01T11:00:57+00:00
    Yeah, SOOOOO much more simple than a tickbox in the keyboard settings of control panel.
