Disable caps lock key
2010-02-01T16:30:30+00:00
I have done web searches on how to disable that pesky caps lock key, but I thought you guys might provide safer answers. I am reasonably proficient with computers, but my fat fingers keeps hitting the CAPS LOCK KEY AND THEN EVERYTHING LOOKS LIKE THIS UNTIL I REALIZE IT AND GO BACK AND re-type it. I do it a lot and it is driving me nuts! Help please!
Thanks so much!
2010-02-01T18:02:04+00:00
I understand that you found some suggestions about registry edition - they are not so bad. If you don't want to download any files which allow you to disable CAPS LOCK, you can create it by your own:
  1. Press WinKey+R > type notepad and press Enter
  2. Paste to the notepad this:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=hex:00,00,00,00,00,00,00,00,02,00,00,00,00,00,3a,00,00,00,00,00 3. File > Save As...
- Select for **Save as type: All Files**
- Enter in the **File name** field: **disable\_caps\_lock.reg**
- Click **Save**
  1. Right click on the created file > Merge
  2. Restart your system
In the case that you want to enable CAPS LOCK again, you need to delete that registry entry, so you need follow these steps:
  1. Press WinKey+R > type regedit and press Enter
  2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout
  3. Right click on the Scancode Map > Delete
  4. Restart your system
I guess it might be the only way to disable CAPS LOCK.
In the case that you still don't want to do that, Windows 7 is offering something different than disabling CAPS LOCK. You can enable Toggle Keys, so you are going to hear a tone when you press CAPS LOCK. To do this follow these steps:
  1. Press Start > Control Panel > Easy of Access   > Easy of Access Center > Make the keyboard easier to use
  2. Mark the Turn on Toggle Keys checkbox
65 additional answers
    2014-01-06T18:27:30+00:00
    On Mon, 6 Jan 2014 17:35:01 +0000, zepe wrote:
    How does one do this in windows 8 and 8.1?
    There are several ways. Here's one easy one:
    http://sharpkeys.codeplex.com/
    2014-02-26T17:16:51+00:00
    Thanks!
    This really helped me!
    Before this, sometimes I was really angry when I notice tHAT MY TEXT IS LIKE THIS. aNNOYING. Not anymore :D!! Easy, effective and awesome! Thanks alot! (NOTICE: This does work in windows 8.1. I did it on windows 8.1 ;D)
    2014-04-16T16:30:48+00:00
    My confusion.....that method actually disables the Caps Lock button where I was looking to just disable the "Caps Lock On" warning box.  thanks though.
    2014-04-16T17:44:20+00:00
    You must have got part of the code wrong, easily done as it is so long1 Try again, as I've just done it on my Macbook, running Windows.
    Some one asked about Macbook running their operating system. Answer is yes, every easy through the internal settings.
