Disable caps lock key
2010-02-01T16:30:30+00:00
I have done web searches on how to disable that pesky caps lock key, but I thought you guys might provide safer answers. I am reasonably proficient with computers, but my fat fingers keeps hitting the CAPS LOCK KEY AND THEN EVERYTHING LOOKS LIKE THIS UNTIL I REALIZE IT AND GO BACK AND re-type it. I do it a lot and it is driving me nuts! Help please!
Thanks so much!
2010-02-01T18:02:04+00:00
I understand that you found some suggestions about registry edition - they are not so bad. If you don't want to download any files which allow you to disable CAPS LOCK, you can create it by your own:
  1. Press WinKey+R > type notepad and press Enter
  2. Paste to the notepad this:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=hex:00,00,00,00,00,00,00,00,02,00,00,00,00,00,3a,00,00,00,00,00 3. File > Save As...
- Select for **Save as type: All Files**
- Enter in the **File name** field: **disable\_caps\_lock.reg**
- Click **Save**
  1. Right click on the created file > Merge
  2. Restart your system
In the case that you want to enable CAPS LOCK again, you need to delete that registry entry, so you need follow these steps:
  1. Press WinKey+R > type regedit and press Enter
  2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout
  3. Right click on the Scancode Map > Delete
  4. Restart your system
I guess it might be the only way to disable CAPS LOCK.
In the case that you still don't want to do that, Windows 7 is offering something different than disabling CAPS LOCK. You can enable Toggle Keys, so you are going to hear a tone when you press CAPS LOCK. To do this follow these steps:
  1. Press Start > Control Panel > Easy of Access   > Easy of Access Center > Make the keyboard easier to use
  2. Mark the Turn on Toggle Keys checkbox
65 additional answers
    2011-02-10T17:55:14+00:00
    @ Drumz
    Are you sure you saved the file as a .REG? Make sure when you select Save As you have the "Save As Type:" set to All Files (as opposed to "Text Documents (*.txt)")
    Also make sure that you copy the text from above VERBATIM:
    Make sure it's ALL of that text, not just [HKEY... and on]
    @Mijinjax
    Worked like a charm. Thank you!
    2011-03-06T18:36:11+00:00
    Why can't you just make an option in the keyboard portion of the control panel that simply disables the capslock? You already have an option to disable capslock by using the shift key.
    The average user should not be messing with the registry.
    2011-07-25T03:24:32+00:00
    worked like a charm, thank you
    2012-03-09T06:16:09+00:00
    In step 4, it is written:   Right click on the created file > Merge
    I had thought when saving the file as a .reg file, it would automatically go to the registry.
    I was wrong.   The file was saved in the last folder I had saved a file in.  Once I found where the.reg file went, it was simply  a matter of right-clicking that new file, choosing the MERGE option, and then giving permission to the dialog boxes that popped up.  After restarting,  voila! the CAPS LOCK key no longer.  Thanks for this great advice.
