Disable caps lock key
2010-02-01T16:30:30+00:00
I have done web searches on how to disable that pesky caps lock key, but I thought you guys might provide safer answers. I am reasonably proficient with computers, but my fat fingers keeps hitting the CAPS LOCK KEY AND THEN EVERYTHING LOOKS LIKE THIS UNTIL I REALIZE IT AND GO BACK AND re-type it. I do it a lot and it is driving me nuts! Help please!
Thanks so much!
2010-02-01T18:02:04+00:00
I understand that you found some suggestions about registry edition - they are not so bad. If you don't want to download any files which allow you to disable CAPS LOCK, you can create it by your own:
  1. Press WinKey+R > type notepad and press Enter
  2. Paste to the notepad this:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=hex:00,00,00,00,00,00,00,00,02,00,00,00,00,00,3a,00,00,00,00,00 3. File > Save As...
- Select for **Save as type: All Files**
- Enter in the **File name** field: **disable\_caps\_lock.reg**
- Click **Save**
  1. Right click on the created file > Merge
  2. Restart your system
In the case that you want to enable CAPS LOCK again, you need to delete that registry entry, so you need follow these steps:
  1. Press WinKey+R > type regedit and press Enter
  2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout
  3. Right click on the Scancode Map > Delete
  4. Restart your system
I guess it might be the only way to disable CAPS LOCK.
In the case that you still don't want to do that, Windows 7 is offering something different than disabling CAPS LOCK. You can enable Toggle Keys, so you are going to hear a tone when you press CAPS LOCK. To do this follow these steps:
  1. Press Start > Control Panel > Easy of Access   > Easy of Access Center > Make the keyboard easier to use
  2. Mark the Turn on Toggle Keys checkbox
65 additional answers
    2017-10-08T10:38:59+00:00
    Thank you very much Mijinjax and Grzegorz, for this thread.
    I had this problem of Caps Lock turning "On" and "Off" by itself.
    I tried lot of ways to resolve this issue, but no gain.
    (installing Windows again, checking for drivers, checking the physical key on the keyboard)
    Ultimately I thought of disabling this Caps lock and I came across this Community Page.
    At last I able to work on my laptop
    Thanks a ton  !
    PS: I have Thinkpad Yoga S1 with Windows 10 (originally it had Windows 8/8.1)
