Disable caps lock key
2010-02-01T16:30:30+00:00
I have done web searches on how to disable that pesky caps lock key, but I thought you guys might provide safer answers. I am reasonably proficient with computers, but my fat fingers keeps hitting the CAPS LOCK KEY AND THEN EVERYTHING LOOKS LIKE THIS UNTIL I REALIZE IT AND GO BACK AND re-type it. I do it a lot and it is driving me nuts! Help please!
Thanks so much!
2010-02-01T18:02:04+00:00
I understand that you found some suggestions about registry edition - they are not so bad. If you don't want to download any files which allow you to disable CAPS LOCK, you can create it by your own:
  1. Press WinKey+R > type notepad and press Enter
  2. Paste to the notepad this:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=hex:00,00,00,00,00,00,00,00,02,00,00,00,00,00,3a,00,00,00,00,00 3. File > Save As...
- Select for **Save as type: All Files**
- Enter in the **File name** field: **disable\_caps\_lock.reg**
- Click **Save**
  1. Right click on the created file > Merge
  2. Restart your system
In the case that you want to enable CAPS LOCK again, you need to delete that registry entry, so you need follow these steps:
  1. Press WinKey+R > type regedit and press Enter
  2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout
  3. Right click on the Scancode Map > Delete
  4. Restart your system
I guess it might be the only way to disable CAPS LOCK.
In the case that you still don't want to do that, Windows 7 is offering something different than disabling CAPS LOCK. You can enable Toggle Keys, so you are going to hear a tone when you press CAPS LOCK. To do this follow these steps:
  1. Press Start > Control Panel > Easy of Access   > Easy of Access Center > Make the keyboard easier to use
  2. Mark the Turn on Toggle Keys checkbox
65 additional answers
    2017-02-02T21:04:52+00:00
    This method works great. I have used it for years. You would think that after all this time developers would simply write in an option to disable various keys on your keybaord. Personally I would disable a few others too. Instead, they seem to be taking options away, or making them more dificult to find. Or, so it seems.
    2017-02-02T21:22:29+00:00
    Hi, I used and posted a complementary review in March 2013!
    Just put Windows 7 back on after trying 10!
    But now MERGE is not an option, The "double click" as suggested by someone, just brings up Notepad!
    Any help appreciated!
    That means when you saved the file, notepad added ".txt" as the file extension.  Rename the file to remove the .txt.  The extension must be .reg, not .reg.txt.
    2017-04-19T04:32:41+00:00
    you are my hero. I've been trying to figure this out for 2 weeks!!
    2017-04-19T17:41:06+00:00
    OMG BRO!!!!
    A person working these forums who knows something!!!!
     They need to promote you to boss and then you go around slapping all the other mods with a glove and firing them then you can hire competent people!
     Is Krzymiński a jewish name or just one they borrowed from the polish?
