Win 7 Desktop does not auto-refresh
2009-11-04T03:31:49+00:00
Saw another thread on this, but no solution.  Two different laptops, both clean installs.  Intermittently, when I delete or move files on the desktop, the icon remains.  I have to manually refresh to clear the deleted/moved files.
Any ideas?
2010-04-07T17:13:28+00:00
Yup, Deckard solved the problem. Here is his post from the other thread for quick reference. His solution worked for me:
"I've read this thread to the end and I've tried all the solutions posted... obviously to no avail.
The bug repeats itself, not randomly but constantly, in any situation, folders, libraries - sorted by name or by whatever.
I then tried something different, which instead WORKED , and here it is.
  1. I backed up the registry.
  2. Searched for occurrences of the word refresh and found this key: HKEY_CLASSES_ROOT\CLSID{BDEADE7F-C265-11D0-BCED-00A0C90AB50F}\Instance
which contains three subkeys. One of them, curiously enough, is DontRefresh and it has a value of 1 (turned ON)
  1. I then changed the value to 0 (turned OFF) and hit F5 to refresh and save the now changed registry.
Guess what? Now, everything (moving, deleting, copying) works and even the Trash Bin refreshes immediately.
I will keep you posted in the next few days to tell you whether the fix still works.
Good luck.
PS: I forgot to say that I have 3 machines and they respectively run Win7 Ult, Win7 Pro and Win7 Home Premium. Of course all of them showed this bug.
  8 days and several reboots since the fix and everything is still working fine on all three machines."
2009-11-04T14:13:31+00:00
Hello tspencer103,
Thank you for posting.
Third party software might be responsible for this behavior. I would suggest you clean boot Windows to find out the culprit. A clean boot helps to eliminate software conflict. Follow the steps in this KB article to perform this task
http://support.microsoft.com/kb/929135
Please post back your findings.
David O
Visit ourand let us know what you think.
86 additional answers
    2010-06-16T19:38:26+00:00
    Thank you, god damn this was the most annoying thing in the world.
    The next most annoying thing is when saving stuff to desktop it saves it to the beginning instead of the end !! grrr
    2010-06-22T15:50:53+00:00
    I'm having the same problem and i decided i would try to rebuild iconcache.db... however, i couldn't find the file and now i wonder if the reason for the desktop auto-refresh problem is that iconcache.db doesn't exist
    I'm no computer genius... so it would be nice if someone... perhaps a professional... could help me out on this theory
    2010-06-28T14:54:53+00:00
    I'm having this issue as well, and none of these work.
