Win 7 Desktop does not auto-refresh
2009-11-04T03:31:49+00:00
Saw another thread on this, but no solution.  Two different laptops, both clean installs.  Intermittently, when I delete or move files on the desktop, the icon remains.  I have to manually refresh to clear the deleted/moved files.
Any ideas?
2010-04-07T17:13:28+00:00
Yup, Deckard solved the problem. Here is his post from the other thread for quick reference. His solution worked for me:
"I've read this thread to the end and I've tried all the solutions posted... obviously to no avail.
The bug repeats itself, not randomly but constantly, in any situation, folders, libraries - sorted by name or by whatever.
I then tried something different, which instead WORKED , and here it is.
  1. I backed up the registry.
  2. Searched for occurrences of the word refresh and found this key: HKEY_CLASSES_ROOT\CLSID{BDEADE7F-C265-11D0-BCED-00A0C90AB50F}\Instance
which contains three subkeys. One of them, curiously enough, is DontRefresh and it has a value of 1 (turned ON)
  1. I then changed the value to 0 (turned OFF) and hit F5 to refresh and save the now changed registry.
Guess what? Now, everything (moving, deleting, copying) works and even the Trash Bin refreshes immediately.
I will keep you posted in the next few days to tell you whether the fix still works.
Good luck.
PS: I forgot to say that I have 3 machines and they respectively run Win7 Ult, Win7 Pro and Win7 Home Premium. Of course all of them showed this bug.
  8 days and several reboots since the fix and everything is still working fine on all three machines."
2009-11-04T14:13:31+00:00
Hello tspencer103,
Thank you for posting.
Third party software might be responsible for this behavior. I would suggest you clean boot Windows to find out the culprit. A clean boot helps to eliminate software conflict. Follow the steps in this KB article to perform this task
http://support.microsoft.com/kb/929135
Please post back your findings.
David O
Visit ourand let us know what you think.
86 additional answers
    2012-02-17T18:29:28+00:00
    thank you so much! this worked for me. i've had this problem for months!
    Good luck.
    2012-03-01T10:33:19+00:00
    Well
    1. Microsoft, stop telling me to clean boot.  My work PC and laptop have this, as does my mediacentre PC at home.  The ONLY thing in common they have is win7 pro x64.  Different AV at home, different software etc.
    My desktop PC hasn't had ANY software installed for months.  This issue started happening a few weeks ago.  It's a Domain registered machine as is my Laptop.
    1. I don't have a DontRefresh anywhere in my registry.
    Its clearly an MS issue.  Think I'll contact my mate who's a field engineer for MS, and get a proper answer.
    2012-03-01T11:06:02+00:00
    Well
    I was having the same prob on one machine for months but not another similar machine with the same OS (Win 7 Pro 64 bit). Didn't have the DontRefresh key either and I tried everything else in the previous threads.
    Eventually I had a total system crash - Windows wouldn't boot, got BSoD repeatedly and couldn't run repair, so I wiped the HDD and reinstalled a clean system from factory condition. Problem gone away. Reinstalled all my apps, problem still gone away for the last couple of months.
