Win 7 Desktop does not auto-refresh
2009-11-04T03:31:49+00:00
Saw another thread on this, but no solution.  Two different laptops, both clean installs.  Intermittently, when I delete or move files on the desktop, the icon remains.  I have to manually refresh to clear the deleted/moved files.
Any ideas?
2010-04-07T17:13:28+00:00
Yup, Deckard solved the problem. Here is his post from the other thread for quick reference. His solution worked for me:
"I've read this thread to the end and I've tried all the solutions posted... obviously to no avail.
The bug repeats itself, not randomly but constantly, in any situation, folders, libraries - sorted by name or by whatever.
I then tried something different, which instead WORKED , and here it is.
  1. I backed up the registry.
  2. Searched for occurrences of the word refresh and found this key: HKEY_CLASSES_ROOT\CLSID{BDEADE7F-C265-11D0-BCED-00A0C90AB50F}\Instance
which contains three subkeys. One of them, curiously enough, is DontRefresh and it has a value of 1 (turned ON)
  1. I then changed the value to 0 (turned OFF) and hit F5 to refresh and save the now changed registry.
Guess what? Now, everything (moving, deleting, copying) works and even the Trash Bin refreshes immediately.
I will keep you posted in the next few days to tell you whether the fix still works.
Good luck.
PS: I forgot to say that I have 3 machines and they respectively run Win7 Ult, Win7 Pro and Win7 Home Premium. Of course all of them showed this bug.
  8 days and several reboots since the fix and everything is still working fine on all three machines."
2009-11-04T14:13:31+00:00
Hello tspencer103,
Thank you for posting.
Third party software might be responsible for this behavior. I would suggest you clean boot Windows to find out the culprit. A clean boot helps to eliminate software conflict. Follow the steps in this KB article to perform this task
http://support.microsoft.com/kb/929135
Please post back your findings.
David O
Visit ourand let us know what you think.
86 additional answers
    2011-11-09T08:39:38+00:00
    I got the same problem on new laptop running Win 7 Pro 64 bit.
    I tried the regsitry key solution but didn't find it.
    I finally solved my problem : I displayed the hidden system files and noticed that I had twh desktop.ini files on my desktop.
    I simply removed these two files and reboot my computer.
    Fred
    2011-11-11T16:50:09+00:00
    I have two Win 7 64-bit machines shipped in summer 2011; Microsoft still has not corrected this bug.
    In the 64-bit registry, I found the key in a different location: HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID{BDEADE7F-C265-11D0-BCED-00A0C90AB50F}\Instance.
    I changed the value of the DontRefresh subkey to 0, as recommended by gc117, and the problem was solved.
    2011-11-11T21:12:26+00:00
    I have/had the same problem, but my solution was different. I don't have the DontRefresh subkey in my registry at all. Never did. I used a registry crawler to search the whole registry but it isn't there.
    What worked for me was a post from another forum somwhere (sorry I forget where), which said they found two desktop.ini files on the desktop when the folder view settings were changed to show hidden files & folders, and show protected operating system files. I had a look on mine, and yep there were two. I deleted them (after zipping them & backing up off disk). Haven't had the problem since, for at least a few days, even with repeated reboots.
