Win 7 Desktop does not auto-refresh
2009-11-04T03:31:49+00:00
Saw another thread on this, but no solution.  Two different laptops, both clean installs.  Intermittently, when I delete or move files on the desktop, the icon remains.  I have to manually refresh to clear the deleted/moved files.
Any ideas?
2010-04-07T17:13:28+00:00
Yup, Deckard solved the problem. Here is his post from the other thread for quick reference. His solution worked for me:
"I've read this thread to the end and I've tried all the solutions posted... obviously to no avail.
The bug repeats itself, not randomly but constantly, in any situation, folders, libraries - sorted by name or by whatever.
I then tried something different, which instead WORKED , and here it is.
  1. I backed up the registry.
  2. Searched for occurrences of the word refresh and found this key: HKEY_CLASSES_ROOT\CLSID{BDEADE7F-C265-11D0-BCED-00A0C90AB50F}\Instance
which contains three subkeys. One of them, curiously enough, is DontRefresh and it has a value of 1 (turned ON)
  1. I then changed the value to 0 (turned OFF) and hit F5 to refresh and save the now changed registry.
Guess what? Now, everything (moving, deleting, copying) works and even the Trash Bin refreshes immediately.
I will keep you posted in the next few days to tell you whether the fix still works.
Good luck.
PS: I forgot to say that I have 3 machines and they respectively run Win7 Ult, Win7 Pro and Win7 Home Premium. Of course all of them showed this bug.
  8 days and several reboots since the fix and everything is still working fine on all three machines."
2009-11-04T14:13:31+00:00
Hello tspencer103,
Thank you for posting.
Third party software might be responsible for this behavior. I would suggest you clean boot Windows to find out the culprit. A clean boot helps to eliminate software conflict. Follow the steps in this KB article to perform this task
http://support.microsoft.com/kb/929135
Please post back your findings.
David O
Visit ourand let us know what you think.
86 additional answers
    2011-04-09T15:43:19+00:00
    This problem is described in this thread:
    Windows Explorer doesn't refresh when moving/deleting
    There is no solution yet to fix this issue.
    Dear David,
    Please let us know when could MS solve this issue by a hotfix, patch, registry editing or any other way?
    I'm sure it's not a novelty for MS, because almost all of the Windows versions (9x, XP, Vista sure) were concerned in this issue.
    I've done the following:
    • deleted IconCache - did not help
    • reset folder views - did not help
    • turned off file sharing and network discovery - did not help
    • made a clean boot (turned off all non MS services in msconfig) - did not help
    • ran sfc - did not found any violations
    • created new user account - did not help
    • updated the BIOS to the latest version - did not help
    • updated the VGA driver to the latest version - did not help
    • turned off file indexing - did not help
    • ran Windows 7 in Safe Mode (without Networking): it seems the issue does not occur (hard to say never occurs, long time test needed - but in Safe Mode it's a bit backward).
    I could be satisfied with Windows 7 but this issue is terribly annoying cause I work with a lot of files day by day.
    Please tell us some information about it!
    I'm looking forward Your answer, sincerely
    Nucleo
    I tried some of the problems  you posted and the one about reseting the folder options worked for me. Thanks.
    2011-07-06T16:04:54+00:00
    MY SOLUTION:
    1. Click Start
    2. Type "change user account control settings"
    3. Change the side bar to the second value "default"
    4. Click ok
    5. press ctrl+shift and dont release
    6. click start
    7. click a blank area with right mouse button
    8. select "EXIT EXPLORER"
    9. release ctrl+shift
    10. press ctrl+shift+esc
    11. go to FILE > New Task
    12. type "explorer"
    13. restart if you wish!
    voilá! :)
    2011-07-24T21:38:14+00:00
    this worked for me
