Win 7 Desktop does not auto-refresh
2009-11-04T03:31:49+00:00
Saw another thread on this, but no solution.  Two different laptops, both clean installs.  Intermittently, when I delete or move files on the desktop, the icon remains.  I have to manually refresh to clear the deleted/moved files.
Any ideas?
2010-04-07T17:13:28+00:00
Yup, Deckard solved the problem. Here is his post from the other thread for quick reference. His solution worked for me:
"I've read this thread to the end and I've tried all the solutions posted... obviously to no avail.
The bug repeats itself, not randomly but constantly, in any situation, folders, libraries - sorted by name or by whatever.
I then tried something different, which instead WORKED , and here it is.
  1. I backed up the registry.
  2. Searched for occurrences of the word refresh and found this key: HKEY_CLASSES_ROOT\CLSID{BDEADE7F-C265-11D0-BCED-00A0C90AB50F}\Instance
which contains three subkeys. One of them, curiously enough, is DontRefresh and it has a value of 1 (turned ON)
  1. I then changed the value to 0 (turned OFF) and hit F5 to refresh and save the now changed registry.
Guess what? Now, everything (moving, deleting, copying) works and even the Trash Bin refreshes immediately.
I will keep you posted in the next few days to tell you whether the fix still works.
Good luck.
PS: I forgot to say that I have 3 machines and they respectively run Win7 Ult, Win7 Pro and Win7 Home Premium. Of course all of them showed this bug.
  8 days and several reboots since the fix and everything is still working fine on all three machines."
2009-11-04T14:13:31+00:00
Hello tspencer103,
Thank you for posting.
Third party software might be responsible for this behavior. I would suggest you clean boot Windows to find out the culprit. A clean boot helps to eliminate software conflict. Follow the steps in this KB article to perform this task
http://support.microsoft.com/kb/929135
Please post back your findings.
David O
Visit ourand let us know what you think.
86 additional answers
    2010-11-15T09:08:26+00:00
    This problem wastes so much time, in XPmode under W7 on teh same laptop - no problem, then I switch to W7 and files do not update - tried all the suggestions the only one that work briefly was to scan the PC "Scandisk" when are MS going to come up witha proper solution?
    2010-12-04T18:20:34+00:00
    I was able to stop it ... I'm not sure if it was a combination of multiple things or just the last thing I did... but here is what I did:
    I shut off Homegroup -- no effect.
    I went into folder options, view, reset folders -- no effect.
    Then I removed the thumb drives I was using with ReadyBoost -- Now it works.
    I'm going to go back and turn on Homegroup and see if that changes it back.
    2010-12-19T14:29:02+00:00
    I Have had this problem occur multiple times each time it seems to start after I change the icons for my computer, recycling bin, and my network places. After I restore these icons to their defaults the refresh problem goes away. I might try changing each icon individually to see if it can be determined if one or all of them are the cause of my problem. Maybe this might help some of you, but it might be a different cause then your desktop refresh problem.
