Screen turns black or grey while using Snipping Tool on Internet Explorer
2010-07-23T17:09:55+00:00
The Snipping tool works fine except when I try to use it in Internet explorer.  The entire screen goes to either black or grey when a snipping tool or "New" is selected.
2010-07-24T16:07:18+00:00
Hi Stansd,
It seems like something in Internet Explorer is preventing Snipping Tool to do its task.
Were you able to capture screenshots earlier from Internet Explorer using Snipping Tool before this issue occurred?
Firstly, check to see if snipping tool works on other web browsers. Also, try the steps mentioned below to see if that help you in fixing the issue.
Step 1: Run Snipping Tool in Administrator mode
a.    Click on Start; in the Start search type Snipping Tool.
b.    Right click on Snipping Tool and choose to “Run as administrator”.
c.    Open Internet Explorer and then try to capture screen shots.
Step 2: Perform a System File Checker
The System File Checker tool (SFC.exe) scans for missing or corrupted system files and repairs them. Visit the link below to know how to perform system file checker scan on your computer.
How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows 7
http://support.microsoft.com/kb/929833
Step 3: Update video drivers on your computer
Visit the link below to know how to update device drivers on your computer
http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
Step 4: Test the issue with a new user account
Visit the link below to knowhow to create a test account
http://windows.microsoft.com/en-us/Windows7/Create-a-user-account
Hope this information is helpful and let me know if you need any further assistance.
Mouneshwar R – Microsoft Support
Visit ourMicrosoft Answers Feedback Forum and let us know what you think
[If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.]
2010-07-24T19:56:19+00:00
Do you see the same behavior from "Safe Mode with Networking"?
Vista Advanced Boot Options (or 7)
http://techblissonline.com/vista-advanced-boot-options/
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/default.aspx/kb/929135
Snipping Tool Fails
http://social.technet.microsoft.com/Forums/en-US/itprovistaapps/thread/610ecb85-9aea-472c-8590-b835a0982f68
44 additional answers
    2015-09-12T10:12:03+00:00
    Trusteer themselves caused the problem by deliberately blocking the Snipping Tool to prevent it being used to capture information by an unauthorised 3rd party. This is very wrong of them to do this without permission and I have complained but received no reply. I have thus got rid of Trusteer and informed my bank upon whose insistence I installed it in the first place.
  2. Deleted
    2015-10-02T21:26:45+00:00
    Hello one more time
    I have been in touch with Trusteer Rapport.
    There is an option within the programme to prevent interference with screen capture. Once this is interference is switch off the SNIPPING TOOL works as normal.
    Only 4/5 hours wasted looking....
    Hope this all helps!
    This worked beautifully.  Only trouble now - how do I get Rapport back and do I have to get rid of it every time I want to snip?
