Screen turns black or grey while using Snipping Tool on Internet Explorer
2010-07-23T17:09:55+00:00
The Snipping tool works fine except when I try to use it in Internet explorer.  The entire screen goes to either black or grey when a snipping tool or "New" is selected.
2010-07-24T16:07:18+00:00
Hi Stansd,
It seems like something in Internet Explorer is preventing Snipping Tool to do its task.
Were you able to capture screenshots earlier from Internet Explorer using Snipping Tool before this issue occurred?
Firstly, check to see if snipping tool works on other web browsers. Also, try the steps mentioned below to see if that help you in fixing the issue.
Step 1: Run Snipping Tool in Administrator mode
a.    Click on Start; in the Start search type Snipping Tool.
b.    Right click on Snipping Tool and choose to “Run as administrator”.
c.    Open Internet Explorer and then try to capture screen shots.
Step 2: Perform a System File Checker
The System File Checker tool (SFC.exe) scans for missing or corrupted system files and repairs them. Visit the link below to know how to perform system file checker scan on your computer.
How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows 7
http://support.microsoft.com/kb/929833
Step 3: Update video drivers on your computer
Visit the link below to know how to update device drivers on your computer
http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
Step 4: Test the issue with a new user account
Visit the link below to knowhow to create a test account
http://windows.microsoft.com/en-us/Windows7/Create-a-user-account
Hope this information is helpful and let me know if you need any further assistance.
Mouneshwar R – Microsoft Support
Visit ourMicrosoft Answers Feedback Forum and let us know what you think
[If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.]
2010-07-24T19:56:19+00:00
Do you see the same behavior from "Safe Mode with Networking"?
Vista Advanced Boot Options (or 7)
http://techblissonline.com/vista-advanced-boot-options/
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/default.aspx/kb/929135
Snipping Tool Fails
http://social.technet.microsoft.com/Forums/en-US/itprovistaapps/thread/610ecb85-9aea-472c-8590-b835a0982f68
44 additional answers
    2012-01-31T17:51:54+00:00
    The same thing happened to me.  Sometimes the snip tool would work, other times not (screen would go black or grey).  I disabled Aero (use a Windows7 Basic theme) and it works all the time again.
    I'm not sure if a Windows update caused the problem or what, but the problem wasn't there originally.  I have a dual core processor, 8gb RAM & 64bit Win7 and I was surprised this happened, but everything seemed to run faster again when I disabled Aero.
    2012-07-24T21:19:17+00:00
    It was definitely Rapport for me, stopped it and it worked.  But it seems sensitive to what's on screen, which would explain the apparent randomness.  It only seems to block the snipper tool if there is something that Rapport deems sensitive displayed.  Not impressed by original "support" from MS though.
    2012-07-24T22:01:17+00:00
    The Rapport support site includes this advice for enabling screen capture on sensitive websites i.e. this procedure allows Rapport to remain active.  I've only tried it once.  It seems to work correctly.
    Trusteer Rapport inhibits capturing screenshots of its protected sites.  This may be overridden in Rapport Advanced policy settings.  When you browse to a protected website Rapport blocks screen capturing attempts to prevent malware from capturing sensitive information that is presented by your browser. A screen capturing program would show black screens when your browser presents a protected website.
    For this reason Remote Desktop software such as LogMeIn, WebEx, VNC, Teamviewer and others will be blocked if Rapport is installed on the Target computer and a protected website is accessed.
    If you are trying to capture the screen of a protected website you should first turn off this specific protection mechanism by following these steps:
    1   Open Rapport Console:
    2   Click the Rapport icon, located next to the browser's address bar, and then click "Open Console", or
    3   Click Start -> All Programs -> Trusteer Rapport -> Rapport Console
    4   Change the policy by following these steps:
    5   At the bottom of the console there is a green right arrow - click it
    6   Click "Edit Policy"
    7   Enter the letters as they are shown in the image and then click OK.
    8   Find "Block Screen Capturing " (1st row)
    9   Next to "Block Screen Capturing", Click the drop down menu and choose "Never"
    10 Click "Save"
    11 Reboot your computer
