I receive Aero Lag when opening and closing windows in Windows 7
2009-11-03T19:47:26+00:00
original title:  Aero Lag when opening and closing windows in Windows 7
UPDATE!!!!!!!!!!!!!!!!!!
OK since we've got the ball rolling here, I am editing this to better reflect what is going on. The below links are just a few out of hundreds of post you will find on the internet about this Aero Lag. Some offer workarounds and some don't. I just Googled Aero Lag and this was from the first page.
If you have the same problem, please provide:
  1. What type of graphics card you have.
  2. What kind of drivers are you using (Win7 preinstalled or manufacturer's drivers)
  3. Was your version of Win7 an update or clean install.
  4. What motherboard you have.
From the sounds of it, Microsoft is looking for a fix.
I also ask for a forum admin to make this a sticky as many people are experiencing this problem.
-Randall
http://www.sevenforums.com/performance-maintenance/22313-aero-lag-good-system.html
http://www.sevenforums.com/graphic-cards/21250-win7-aero-windows-have-choppy-delay-when-opening.html
http://social.technet.microsoft.com/Forums/en-US/w7itproperf/thread/a013396d-8953-4e32-8d13-f2d119cd730d
http://www.flamehaus.com/bbs/-vp3478764.html
http://www.youtube.com/watch?v=YKNj_90E_PI
http://www.hardforum.com/showthread.php?t=1465844
http://windows7forums.com/windows-7-hardware/1549-windows-7-video-lag.html
http://windows7forums.com/windows-7-software/23315-gaming-video-lag-choppyness.html
http://windows7forums.com/windows-7-support/5287-aero-lags-when-open-new-programs.html
http://forum.eeeuser.com/viewtopic.php?id=66007
http://www.neowin.net/forum/lofiversion/index.php/t787172.html
http://www.youtube.com/watch?v=YWdVrSUhvLE
Randall
2011-01-13T22:36:16+00:00
**Have solved my problem withAeor lag.**Reinstall Windows 7 U64 twice with new/old driver.
Replaced Gforce 8800GTX with Gforce GTX480.
Have spent many days on this problem without a solution.
But here is a very simple solution that works for me.
I removed the USB extension cablefor my CreativeHS-1200WirelessUSB Gaming Headset.
Aero lags when Iused USB extension cable and headset charging.
Without USB extension cable, everything is fine.
So it think itis a voltagedrop in the USB extension cable,causes the system to lag. ?
Hope it can help.
Sincerely,
Dennis Psilander
291 additional answers
    2009-12-27T17:34:38+00:00
    Hello, i've just upgraded my laptop from vista 64 bit to 7 64 bit and i too see the defect that people are talking about. Only when opening windows and closing windows, the snap of opening or de-snap of closing windows gives it a cheap feel. Its easier to see when opening a window that is not maximized to the screen when it opens and when closing a none maximized window. I think the average computer user would never even notice because it happens very quick. Of course turning off window animation fixes the problem permanently.....even using the magnifier program as a user stated above does correct the problem till the next reboot. I'm gonna go to Best Buy to check out some deals, while i am there i am going to check and see with my eyes as other people here have just to see if this happens on those computers in store.
    Its only a minor thing but i hope it gets fixed. Other than that i'm enjoying 7 over Vista.
    2009-12-31T15:13:53+00:00
    I also discovered the not-so-smooth animation problem when opening and closing new program windows. On every computer I could check I verified this nuisance. But I don't think, that the drivers are to blame here...
    Win7 is said to rely on hardware 2d-funcitons for zooming and displaying its windows. If this wouldn't work properly, the whole desktop should be a mess... I rather seems to me, that since the animations are calculated in realtime (think about all the possible windowsizes!), this calculation isn't right.
    Namely, the zooming decelerates too quickly for the amount of time the animation is supposed to take, resulting in never reaching the final size its supposed to. And since after the animation finished, the program window is redrawn in its original size, the gap between these two size looks like the window is finally "popping up".  The magnifying tool strangely seems to reset parameters used for these calculations... I don't know - it's a mistery! :)
    You could actually test the slowlyness of Aero by opening the task manager, maximizing its windows, switch to services and playing around with the columnsizes. At leat on all of the computers I checked, well, that was slow!
    Maybe the rumors are right, and ATI as well as Nvidea has stripped their chips from all 2d-hardware-acceleration. Then Direct2D wouldn't be of any help here and rather slows everything down! I guess someone with an old vga-card (>3-4 years) should check there, but then Aero wouldn't work anyway, right?
    2009-12-31T19:18:39+00:00
    This issue is also visible with Aero OFF, at least for me. I don't think this has anything to do with Aero. Try it yourself and post back.
    2010-01-01T06:30:07+00:00
    Happy new year by the way.
    i don't have those display issues when putting windows into basic mode. Also, just by turning off the window animation properties and keeping aero runnin also corrects the problem.
    I did end up going to Best Buy, all the computers i tried there had exactly the same issue.
    We might as well assume and hope this will be corrected in the next service pack.
