I receive Aero Lag when opening and closing windows in Windows 7
2009-11-03T19:47:26+00:00
original title:  Aero Lag when opening and closing windows in Windows 7
UPDATE!!!!!!!!!!!!!!!!!!
OK since we've got the ball rolling here, I am editing this to better reflect what is going on. The below links are just a few out of hundreds of post you will find on the internet about this Aero Lag. Some offer workarounds and some don't. I just Googled Aero Lag and this was from the first page.
If you have the same problem, please provide:
  1. What type of graphics card you have.
  2. What kind of drivers are you using (Win7 preinstalled or manufacturer's drivers)
  3. Was your version of Win7 an update or clean install.
  4. What motherboard you have.
From the sounds of it, Microsoft is looking for a fix.
I also ask for a forum admin to make this a sticky as many people are experiencing this problem.
-Randall
http://www.sevenforums.com/performance-maintenance/22313-aero-lag-good-system.html
http://www.sevenforums.com/graphic-cards/21250-win7-aero-windows-have-choppy-delay-when-opening.html
http://social.technet.microsoft.com/Forums/en-US/w7itproperf/thread/a013396d-8953-4e32-8d13-f2d119cd730d
http://www.flamehaus.com/bbs/-vp3478764.html
http://www.youtube.com/watch?v=YKNj_90E_PI
http://www.hardforum.com/showthread.php?t=1465844
http://windows7forums.com/windows-7-hardware/1549-windows-7-video-lag.html
http://windows7forums.com/windows-7-software/23315-gaming-video-lag-choppyness.html
http://windows7forums.com/windows-7-support/5287-aero-lags-when-open-new-programs.html
http://forum.eeeuser.com/viewtopic.php?id=66007
http://www.neowin.net/forum/lofiversion/index.php/t787172.html
http://www.youtube.com/watch?v=YWdVrSUhvLE
Randall
2011-01-13T22:36:16+00:00
**Have solved my problem withAeor lag.**Reinstall Windows 7 U64 twice with new/old driver.
Replaced Gforce 8800GTX with Gforce GTX480.
Have spent many days on this problem without a solution.
But here is a very simple solution that works for me.
I removed the USB extension cablefor my CreativeHS-1200WirelessUSB Gaming Headset.
Aero lags when Iused USB extension cable and headset charging.
Without USB extension cable, everything is fine.
So it think itis a voltagedrop in the USB extension cable,causes the system to lag. ?
Hope it can help.
Sincerely,
Dennis Psilander
291 additional answers
    2009-12-15T12:07:59+00:00
    And you have no comment about Notepad, which opens lightning fast?  Nor do you have a comment about the instantaneous opening when you disable Animate Windows?
    I'm not denying you guys are seeing something - you're seeing the different way Windows 7 opens its windows vs. older kernels.  What I'm saying is that you are making a mountain out of a molehill.  It is easily negated by disabling that one checkbox.  This thread of over 100 posts is laughable based on the fact that disabling that option puts things back the way they were in Windows 2000, basically.
    Look at how metrosexual you're being about what is essentially a non-starter.  You had to go FRAME BY FRAME and analyze the video to even notice a problem.  What does that tell you?
    I gave up on this thread a long time ago when I realized that the people driving it had way too much time on their hands. Yes, they are correct. There is an ever so slight lag (or snap to) on opening and a slight hesitation on closing. But it's really not worth worrying about in a world where 30,000 people are being sent to a pointless war or health care reform can't get passed, etc. (well, you get my point).
    What I'm REALLY writing about is the the "metrosexual" comment. What do you mean by that precisely? And, if it's what I think it is, you really need to check yourself. That kind of bigotry isn't to be tolerated on a public forum in 2009.
    Happy holidays to all. Get lives.
    Thank you. Your comment was so helpful. Now the problem is solved. Everytime I buy a new product and I see that something is wrong, I just shut up and accept it. Great.
    2009-12-15T17:53:28+00:00
    If the "issue" with which you are concerned is mind bogglingly trivial then I guess the resounding answer to your question would be "yes". Glad I was able to clarify that for you. Now you can work on getting on with living and not being held hostage to the products you use in an ____-retentive kind of way.
    Cheers!
    2009-12-15T18:03:06+00:00
    I thought I made myself clearer in earlier posts.
    This issue is far from trivial. It's a half-a**ed, stuck in between new style and old style window animation. It either needs to be one or the other. The most important thing is that at its worst, it MESSES UP MY WORKFLOW. Part of what I do for a living is making music. If you have many windows constantly opening and closing at a time, for instance, to edit single notes, the "snap", "lag", or whatever you want to call it can make me click the wrong window by accident and edit the wrong one because I think the window has either frozen, not closed, or is still open. In that small amount of time that it takes that window to snap, I can click and focus another window.
    Since this is the case, it is a bug, and needs to be fixed. If I am sitting there just browsing around on the internet and checking my e-mail, or wasting my time on social networking sites, then, of course, it's no big deal. But I actually use my computer for a living. That being said, we need an answer from Microsoft.
    2009-12-15T18:08:22+00:00
    It's trivial. I use Windows 7 everyday. It amounts to nothing in the microscopic and grand view of things. It doesn't bother me, and it shouldn't bother you. There, I've fixed the whole thing for you. My psychiatric consultation bill is in the mail! Maybe MS will "fix" the issue in SP1. If they do, GREAT; if they don't, GREAT!
    Really, you need to move on ... very bad karma! Save yourself the keystrokes; this is my last post on the topic.
    Happy holidays!
