I receive Aero Lag when opening and closing windows in Windows 7
2009-11-03T19:47:26+00:00
original title:  Aero Lag when opening and closing windows in Windows 7
UPDATE!!!!!!!!!!!!!!!!!!
OK since we've got the ball rolling here, I am editing this to better reflect what is going on. The below links are just a few out of hundreds of post you will find on the internet about this Aero Lag. Some offer workarounds and some don't. I just Googled Aero Lag and this was from the first page.
If you have the same problem, please provide:
  1. What type of graphics card you have.
  2. What kind of drivers are you using (Win7 preinstalled or manufacturer's drivers)
  3. Was your version of Win7 an update or clean install.
  4. What motherboard you have.
From the sounds of it, Microsoft is looking for a fix.
I also ask for a forum admin to make this a sticky as many people are experiencing this problem.
-Randall
http://www.sevenforums.com/performance-maintenance/22313-aero-lag-good-system.html
http://www.sevenforums.com/graphic-cards/21250-win7-aero-windows-have-choppy-delay-when-opening.html
http://social.technet.microsoft.com/Forums/en-US/w7itproperf/thread/a013396d-8953-4e32-8d13-f2d119cd730d
http://www.flamehaus.com/bbs/-vp3478764.html
http://www.youtube.com/watch?v=YKNj_90E_PI
http://www.hardforum.com/showthread.php?t=1465844
http://windows7forums.com/windows-7-hardware/1549-windows-7-video-lag.html
http://windows7forums.com/windows-7-software/23315-gaming-video-lag-choppyness.html
http://windows7forums.com/windows-7-support/5287-aero-lags-when-open-new-programs.html
http://forum.eeeuser.com/viewtopic.php?id=66007
http://www.neowin.net/forum/lofiversion/index.php/t787172.html
http://www.youtube.com/watch?v=YWdVrSUhvLE
Randall
2011-01-13T22:36:16+00:00
**Have solved my problem withAeor lag.**Reinstall Windows 7 U64 twice with new/old driver.
Replaced Gforce 8800GTX with Gforce GTX480.
Have spent many days on this problem without a solution.
But here is a very simple solution that works for me.
I removed the USB extension cablefor my CreativeHS-1200WirelessUSB Gaming Headset.
Aero lags when Iused USB extension cable and headset charging.
Without USB extension cable, everything is fine.
So it think itis a voltagedrop in the USB extension cable,causes the system to lag. ?
Hope it can help.
Sincerely,
Dennis Psilander
291 additional answers
    2009-12-05T16:46:31+00:00
    Just chiming in that I also have this issue. I noticed it from the very first time I closed a window in Windows 7 with Aero on and it bothered me. I could initially not find any massive threads of people with the same problem so I'm glad I found this one.  It is only when opening and closing windows. Anyone who has it when minimizing and maximizing likely just has a slow machine, AND WE ARE LIKELY NOT TALKING ABOUT THE SAME BUG. I am a system builder with over 13 years of experience. IT IS on every Windows 7 machine I have build/installed it on, whether people realize it or not. It IS THERE regardless of what drivers are installed. If microsoft cannot see/replicate the issue, they are clearly blind and need to have someone such as myself sit next to them and demonstrate the issue, and say "LOOK, DON'T YOU SEE THAT!"  :)
    Many users will not notice this because they are not ____ about it. I can't believe this forum is blocking out the word an-al. They don't pay attention to small details like this, and that is fine. Nothing wrong with that, but there is something wrong with Windows 7's aero. Vista's aero on the same exact hardware I am listing below is 100% smooth. **I agree in that I think it is a missing frame that should be there, but isn't.**The scary thing is that the designers may have done this on purpose to make it look a little different from Vista's Aero.
    My specs:
    Asus Rampage Formula X48
    Intel QX9650 at 4.2GHZ
    XFX GTX280 XXX
    Asus Xonar D2X Sound Card
    8GB's Ram
    3ware 9650SE Raid Card
    2X 1TB Samsung Spinpoint F1's in Raid 0
    2009-12-05T22:30:48+00:00
    Just chiming in that I also have this issue. I noticed it from the very first time I closed a window in Windows 7 with Aero on and it bothered me. I could initially not find any massive threads of people with the same problem so I'm glad I found this one.  It is only when opening and closing windows . Anyone who has it when minimizing and maximizing likely just has a slow machine, AND WE ARE LIKELY NOT TALKING ABOUT THE SAME BUG . I am a system builder with over 13 years of experience. IT IS on every Windows 7 machine I have build/installed it on, whether people realize it or not. It IS THERE regardless of what drivers are installed. If microsoft cannot see/replicate the issue, they are clearly blind and need to have someone such as myself sit next to them and demonstrate the issue, and say "LOOK, DON'T YOU SEE THAT!"  :)
    You're exactly right. I do fear that Microsoft would have "done this on purpose". If they did, words fail to describe what I'd like to call them. Most likely the forums would block out what I try to say.
    2009-12-06T00:09:17+00:00
    i get the same thing when open and close lag. I didnt like it so went back to vista
    My specs:
    MSI :KA780G mobo
    4gb of ram @800mhz
    ati3200 yes it sucks but should run Aero fine
    hdd: 300gb 200gb
    2009-12-09T23:46:20+00:00
    I'm also getting this lag or snap, whatever you want to call it. It's very annoying. I hope this gets a fix soon. I always liked the animation in Vista so I'm won't consider turing it off in Windows 7.
    Specs are:
    Windows 7 x64
    ASUS P5Q Deluxe mobo
    Core2Duo E8400 @ 3.6GHz
    4GB Ram
    GTX260 OCX
    2 x 500GB HDD's
