I receive Aero Lag when opening and closing windows in Windows 7
2009-11-03T19:47:26+00:00
original title:  Aero Lag when opening and closing windows in Windows 7
UPDATE!!!!!!!!!!!!!!!!!!
OK since we've got the ball rolling here, I am editing this to better reflect what is going on. The below links are just a few out of hundreds of post you will find on the internet about this Aero Lag. Some offer workarounds and some don't. I just Googled Aero Lag and this was from the first page.
If you have the same problem, please provide:
  1. What type of graphics card you have.
  2. What kind of drivers are you using (Win7 preinstalled or manufacturer's drivers)
  3. Was your version of Win7 an update or clean install.
  4. What motherboard you have.
From the sounds of it, Microsoft is looking for a fix.
I also ask for a forum admin to make this a sticky as many people are experiencing this problem.
-Randall
http://www.sevenforums.com/performance-maintenance/22313-aero-lag-good-system.html
http://www.sevenforums.com/graphic-cards/21250-win7-aero-windows-have-choppy-delay-when-opening.html
http://social.technet.microsoft.com/Forums/en-US/w7itproperf/thread/a013396d-8953-4e32-8d13-f2d119cd730d
http://www.flamehaus.com/bbs/-vp3478764.html
http://www.youtube.com/watch?v=YKNj_90E_PI
http://www.hardforum.com/showthread.php?t=1465844
http://windows7forums.com/windows-7-hardware/1549-windows-7-video-lag.html
http://windows7forums.com/windows-7-software/23315-gaming-video-lag-choppyness.html
http://windows7forums.com/windows-7-support/5287-aero-lags-when-open-new-programs.html
http://forum.eeeuser.com/viewtopic.php?id=66007
http://www.neowin.net/forum/lofiversion/index.php/t787172.html
http://www.youtube.com/watch?v=YWdVrSUhvLE
Randall
2011-01-13T22:36:16+00:00
**Have solved my problem withAeor lag.**Reinstall Windows 7 U64 twice with new/old driver.
Replaced Gforce 8800GTX with Gforce GTX480.
Have spent many days on this problem without a solution.
But here is a very simple solution that works for me.
I removed the USB extension cablefor my CreativeHS-1200WirelessUSB Gaming Headset.
Aero lags when Iused USB extension cable and headset charging.
Without USB extension cable, everything is fine.
So it think itis a voltagedrop in the USB extension cable,causes the system to lag. ?
Hope it can help.
Sincerely,
Dennis Psilander
291 additional answers
    2009-12-03T19:07:33+00:00
    There are alot of people that either are to obivious to the open/close lag issue or they just don't care about it.   It is a proven fact that the lag issue is on 99% of all PC's.  Anyone who uses the workaround is just avoiding the fact there is a problem within the OS.  It doesn't matter what hardware you have, it's there.  I have a quad core, 4GB DDR2 800 and HD 4890 1GB and I still have the issue.  It's not my system thats for sure...Vista didn't have the issue...silky smooth transition across the board.  When you pay a premium for a product you expect it to be 99% flawless...yeah there will bugs...but to do a workaround on Windows 7 is out of the question for me.  I have "some" faith in Microsoft that this will be resolved soon.   Give them a break...they have alot of stuff going on....the Lag issue is not the only thing they need to fix...
    2009-12-03T19:31:08+00:00
    as always one has to wait for sp2 to see most of the bugs fixed. sucks but true and i am not going to install 7  till sp2 comes out.
    2009-12-03T19:33:56+00:00
    I have mutiple Hard Drives.  Right now I'm only using my 500GB WD for Windows 7, and 1TB for Storage...I also have a 320GB that I plan on install Windows Vista on.  That way I have both OS's and depending on if I'm gaming or doing web/editing stuff I will switch between the two.  You never know if SP1 will have the fix...this one was found really early...so there is a good chance that it may be fixed by then.
    2009-12-03T20:34:03+00:00
    Since upgrading to 7 the only issues I have had was the internet disconnecting(error 651) which was resolved by downloading fresh drivers for
    the network controller and the "slight" window lag when closing.  The windows would MINIMIZE AND MAXIMIZE just fine, but stutter upon closing.   So by turning the ANIMATION off it corrected it for me is all I'm saying.  I don't doubt there will be issues with 7 but nothing is "lagging" with my system now. Another friend who is running 7 isn't experencing any lag issue at all.  Sorry to hear about your troubles, just trying to help.
    I'm happy for now with just "masking" the issue because it worked for me.  Just like so many others have posted I am sure MS will eventually fix the problem and release it to the public when its ready and working properly.
