I receive Aero Lag when opening and closing windows in Windows 7
2009-11-03T19:47:26+00:00
original title:  Aero Lag when opening and closing windows in Windows 7
UPDATE!!!!!!!!!!!!!!!!!!
OK since we've got the ball rolling here, I am editing this to better reflect what is going on. The below links are just a few out of hundreds of post you will find on the internet about this Aero Lag. Some offer workarounds and some don't. I just Googled Aero Lag and this was from the first page.
If you have the same problem, please provide:
  1. What type of graphics card you have.
  2. What kind of drivers are you using (Win7 preinstalled or manufacturer's drivers)
  3. Was your version of Win7 an update or clean install.
  4. What motherboard you have.
From the sounds of it, Microsoft is looking for a fix.
I also ask for a forum admin to make this a sticky as many people are experiencing this problem.
-Randall
http://www.sevenforums.com/performance-maintenance/22313-aero-lag-good-system.html
http://www.sevenforums.com/graphic-cards/21250-win7-aero-windows-have-choppy-delay-when-opening.html
http://social.technet.microsoft.com/Forums/en-US/w7itproperf/thread/a013396d-8953-4e32-8d13-f2d119cd730d
http://www.flamehaus.com/bbs/-vp3478764.html
http://www.youtube.com/watch?v=YKNj_90E_PI
http://www.hardforum.com/showthread.php?t=1465844
http://windows7forums.com/windows-7-hardware/1549-windows-7-video-lag.html
http://windows7forums.com/windows-7-software/23315-gaming-video-lag-choppyness.html
http://windows7forums.com/windows-7-support/5287-aero-lags-when-open-new-programs.html
http://forum.eeeuser.com/viewtopic.php?id=66007
http://www.neowin.net/forum/lofiversion/index.php/t787172.html
http://www.youtube.com/watch?v=YWdVrSUhvLE
Randall
2011-01-13T22:36:16+00:00
**Have solved my problem withAeor lag.**Reinstall Windows 7 U64 twice with new/old driver.
Replaced Gforce 8800GTX with Gforce GTX480.
Have spent many days on this problem without a solution.
But here is a very simple solution that works for me.
I removed the USB extension cablefor my CreativeHS-1200WirelessUSB Gaming Headset.
Aero lags when Iused USB extension cable and headset charging.
Without USB extension cable, everything is fine.
So it think itis a voltagedrop in the USB extension cable,causes the system to lag. ?
Hope it can help.
Sincerely,
Dennis Psilander
291 additional answers
    2009-12-01T16:02:58+00:00
    Hello, Microsoft.
     Is anybody working on this issue? Or will there anybody work on this issue? An answer would be great.
    This is not the first thread about this issue. An example: "Anyone else get the Window 7 aero stutter when closing open windows? It goes: "click on the "x" to close, fading, pause, fading, gone". It happens very quick, but its annoying." This is from April. http://forums.guru3d.com/showthread.php?t=294109
    2009-12-03T15:54:07+00:00
    Here is what I did to stop this little annoyance...
    Go to Control Panel>System & Security>System, Click on Advanced system settings in the left pane.
    In System Properties select the Visual Effects tab and click on Perfomance. Uncheck the "Animate windows when minimizing
    and maximizing" box, then apply and save. I was having the same issue before, as everyone is, and this solved it. Now
    all windows are opening and closing lightning fast.
    Hope this helps!
    2009-12-03T16:15:45+00:00
    Problem Solved!!!
    Here is what you need to do.  Go to Control Panel>System & Security>System then click on Advanced system setting in the left pane.
    Next click on the Advanced tab.  Click "Setting" in the Performance option, select the Visual Effects tab.  Once there select custom, if not
    already chosen, and uncheck the "Animate windows when minimizing and maximizing" box, apply and save.  It worked great for me and
    now all windows open and close lightening fast.  Hope this works for you!
    2009-12-03T18:00:25+00:00
    The problem that we are having is NOT WITH MINIMIZING AND MAXIMIZING. It's with windows OPENING AND CLOSING. The previous post which claims to "solve" the problem is not a solution. It is a workaround to an unrelated issue.
    The situation remains. I certainly hope Microsoft does something about it and doesn't end up giving us an excuse as an answer.
