I receive Aero Lag when opening and closing windows in Windows 7
2009-11-03T19:47:26+00:00
original title:  Aero Lag when opening and closing windows in Windows 7
UPDATE!!!!!!!!!!!!!!!!!!
OK since we've got the ball rolling here, I am editing this to better reflect what is going on. The below links are just a few out of hundreds of post you will find on the internet about this Aero Lag. Some offer workarounds and some don't. I just Googled Aero Lag and this was from the first page.
If you have the same problem, please provide:
  1. What type of graphics card you have.
  2. What kind of drivers are you using (Win7 preinstalled or manufacturer's drivers)
  3. Was your version of Win7 an update or clean install.
  4. What motherboard you have.
From the sounds of it, Microsoft is looking for a fix.
I also ask for a forum admin to make this a sticky as many people are experiencing this problem.
-Randall
http://www.sevenforums.com/performance-maintenance/22313-aero-lag-good-system.html
http://www.sevenforums.com/graphic-cards/21250-win7-aero-windows-have-choppy-delay-when-opening.html
http://social.technet.microsoft.com/Forums/en-US/w7itproperf/thread/a013396d-8953-4e32-8d13-f2d119cd730d
http://www.flamehaus.com/bbs/-vp3478764.html
http://www.youtube.com/watch?v=YKNj_90E_PI
http://www.hardforum.com/showthread.php?t=1465844
http://windows7forums.com/windows-7-hardware/1549-windows-7-video-lag.html
http://windows7forums.com/windows-7-software/23315-gaming-video-lag-choppyness.html
http://windows7forums.com/windows-7-support/5287-aero-lags-when-open-new-programs.html
http://forum.eeeuser.com/viewtopic.php?id=66007
http://www.neowin.net/forum/lofiversion/index.php/t787172.html
http://www.youtube.com/watch?v=YWdVrSUhvLE
Randall
2011-01-13T22:36:16+00:00
**Have solved my problem withAeor lag.**Reinstall Windows 7 U64 twice with new/old driver.
Replaced Gforce 8800GTX with Gforce GTX480.
Have spent many days on this problem without a solution.
But here is a very simple solution that works for me.
I removed the USB extension cablefor my CreativeHS-1200WirelessUSB Gaming Headset.
Aero lags when Iused USB extension cable and headset charging.
Without USB extension cable, everything is fine.
So it think itis a voltagedrop in the USB extension cable,causes the system to lag. ?
Hope it can help.
Sincerely,
Dennis Psilander
291 additional answers
    2009-11-15T20:29:00+00:00
    Maybe it's for AMD3 only, not quite sure. But now, after a day's time, it really doesn't look much of a difference. Plus, I think being on this forum excellerates the problem, cause I just now got lag.
    2009-11-16T01:23:51+00:00
    Ok, I've modified the registry to the specifications of that link you provided, made sure that the aero animations are enabled and when using the shift key in conjunction with the opening/closing, min/maximizing...etc., there is a HUGE difference.  It is still relatively smooth though.  I do however NOW see the lag that everyone is talking about although I don't think (in my opinion anyway) that it's very pronounced - however, it is visible now whereas it was not before.  But that is supposed to happen though isn't it because of the modification of the registry?
    2009-11-16T16:36:33+00:00
    Well, it's Monday! Good new week to us all, let's see if a solution is found!
    On another note, I took out my 3rd stick of RAM to see if it helped. It did a little, I think (I was drunk when I did it). But I have only seen very little lag since removing it.
    Randall
    2009-11-16T17:40:42+00:00
    I have this dreaded problem too with my GeForce 9800 GTX+ (4GB DDR2 800MHz ram, Core 2 Duo E8400...). It was butter smooth in Vista Business x64 but not anymore with 7 Professional x64.
