I receive Aero Lag when opening and closing windows in Windows 7
2009-11-03T19:47:26+00:00
original title:  Aero Lag when opening and closing windows in Windows 7
UPDATE!!!!!!!!!!!!!!!!!!
OK since we've got the ball rolling here, I am editing this to better reflect what is going on. The below links are just a few out of hundreds of post you will find on the internet about this Aero Lag. Some offer workarounds and some don't. I just Googled Aero Lag and this was from the first page.
If you have the same problem, please provide:
  1. What type of graphics card you have.
  2. What kind of drivers are you using (Win7 preinstalled or manufacturer's drivers)
  3. Was your version of Win7 an update or clean install.
  4. What motherboard you have.
From the sounds of it, Microsoft is looking for a fix.
I also ask for a forum admin to make this a sticky as many people are experiencing this problem.
-Randall
http://www.sevenforums.com/performance-maintenance/22313-aero-lag-good-system.html
http://www.sevenforums.com/graphic-cards/21250-win7-aero-windows-have-choppy-delay-when-opening.html
http://social.technet.microsoft.com/Forums/en-US/w7itproperf/thread/a013396d-8953-4e32-8d13-f2d119cd730d
http://www.flamehaus.com/bbs/-vp3478764.html
http://www.youtube.com/watch?v=YKNj_90E_PI
http://www.hardforum.com/showthread.php?t=1465844
http://windows7forums.com/windows-7-hardware/1549-windows-7-video-lag.html
http://windows7forums.com/windows-7-software/23315-gaming-video-lag-choppyness.html
http://windows7forums.com/windows-7-support/5287-aero-lags-when-open-new-programs.html
http://forum.eeeuser.com/viewtopic.php?id=66007
http://www.neowin.net/forum/lofiversion/index.php/t787172.html
http://www.youtube.com/watch?v=YWdVrSUhvLE
Randall
2011-01-13T22:36:16+00:00
**Have solved my problem withAeor lag.**Reinstall Windows 7 U64 twice with new/old driver.
Replaced Gforce 8800GTX with Gforce GTX480.
Have spent many days on this problem without a solution.
But here is a very simple solution that works for me.
I removed the USB extension cablefor my CreativeHS-1200WirelessUSB Gaming Headset.
Aero lags when Iused USB extension cable and headset charging.
Without USB extension cable, everything is fine.
So it think itis a voltagedrop in the USB extension cable,causes the system to lag. ?
Hope it can help.
Sincerely,
Dennis Psilander
291 additional answers
    2009-11-09T18:00:54+00:00
    I am so glad I stumbled upon this discussion.
    I have been using Vista x64 for about a year now, and I upgraded to Windows 7 x64 last night.
    I had tried out my Windows 7 when using Vista, in a Virtual Machine, just to see if I would like Windows 7, and I thought the "micro-lag" issue was just because I was running in a Virtual Machine.
    When I formatted my system drive and installed Windows 7 last night, and started to use it, I noticed the "micro-lag" in the window animations immediately.Vista had no such lag.
    My system specs:
    ASUS P5Q Pro
    Intel Q6600 @ 3.6ghz
    8GB RAM
    ATI 4850
    Latest drivers, etc.
    Again, Vista x64 was smooth and perfect.  Windows 7 has "micro-lag" in the window animations.
    2009-11-09T18:28:46+00:00
    It is good that this issue is getting some attention - I thought I was seeing things at first....
    Let me emphasize the following:
    This is a subtle issue.  I consider myself an advanced power-user, and I know when an interface feels different from that of one I am used to.   Please do not confuse this issue with a simple "hardware not capable" problem.
    My system specs:
    ASUS P5Q Pro
    8GB RAM
    ATI 4850
    **Again, Vista x64 was smooth and perfect.  Windows 7 has "micro-lag" in the window animations.This may not be an actual "lag."  It may be simply a graphical draw sequence issue.**Other than that, I really enjoy using 7.  A lot of the tiny problems with Vista (which I enjoyed using too) have been fixed.  To me, this lag issue seems like an easy fix.
    2009-11-10T01:29:11+00:00
    I think the issues may be related. The sound card is often the best indicator of a resource issue if it falls foul of it. Heck, it may even affect other systems and cause graphic stuttering. That said, it is more likely to be of use as a canary. This could be a red herring, but in the absence of a better line of enquiry we may as well look it over.
    If the hardware resource management in Win7 is a bit flakey, it could affect loads of H/W combinations. Tool, your setup couldn't be more different to MicOff's (except the mobo is the same make, but a very different design as MicOff's is an AMD system).
    I still think some people (ie. me) are possibly just not noticing the problem. Can anyone with the problem claim to also have or have seen a retail copy of Win7 Aero version without this problem? And I mean sabble, for the long haul. I know some have seen it develop after a while, but I'm looking for someone who can see the problem and so can verify that not all systems suffer. If they cannot be found, this may be a universal problem that some don't notice.
    2009-11-10T01:42:15+00:00
    Right, this is a left field suggestion, and a bit involved, but take a look at this thread:
    http://forums.extremeoverclocking.com/showthread.php?t=251435
    Now this is Vista here, but it could be worth a try. Especially for the sound card issues.
